Clutch will not fully disengage (pedal depressed)
Old May 29, 2010 | 07:17 PM
JFack's Avatar
So my clutch just decided it doesn't want to fully disengage, meaning go all the way to the floor. it goes about halfway then stops and feels squishy, like theres a ball behind it. I can still change gears but I have a feeling that won't be for long.
I was told it might just have lost transmission fluid, but I can't find the dang transmission plug to check it. My stupid haynes manual doesn't provide a picture of where its located.
My cars a 89 RS 305 5 speed, any help would be appreciated.
Old May 29, 2010 | 07:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Clutch will not fully disengage (pedal depressed)
the fluid they were refeering to is for the clutch hydraulics, not the transmission fluid.
there is a reservoir attached to a bracket off the brake booster on the driverside. Thats for the clutch hydraulics. see if there is anything in it.
Old May 29, 2010 | 07:47 PM
JFack's Avatar
Yes, your right that is what I meant, but it seems full so I don't know what the hecks wrong with my car.
Old May 29, 2010 | 07:56 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Sounds like either the clutch master, or slave cylinder are going out.
My master cylinder was going out, and it was a PAIN to drive the car, the clutch will slowly engage itself no matter if you want it to or not. They are both a huge pain to replace, though.
Check them for leaks.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
