Helpful T56 Info!
Old Aug 15, 2011 | 11:08 PM
  #51
383Bandit's Avatar
Re: Helpful T56 Info!
Are you talking about using an LT1 tranny mated to an LS engine?
Old Aug 17, 2011 | 11:38 AM
  #52
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
No standard SBC
Old Aug 17, 2011 | 05:51 PM
  #53
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Originally Posted by formula350sd
Just a note if you plan to swap to a t-56 from an lt-1 you can use a standard push clutch with a custom throwout bearing and scattershield from mccloud if anyone is interested I can post pics and possibly part numbers if I can find them.
Id like to see that, t56 is my next endeavor, im also confused on how im gonna get a speedo working without machining my t56 for a cable, I want to use aftermarket electric gauges and ill have a 7730 ecm in with the vss buffer box in there, how does the lt trans send the speed signal? Thru a sensor?
Old Aug 23, 2011 | 11:59 AM
  #54
Car: 89 Formula
Ok it took me a while to dig up the part numbers but for the bellhousing
mcl-8710-15
and associated throwout bearing
mcl-1400-22
This was NOT cheap but it's very very nice and works extremely well...
Old Oct 2, 2011 | 01:07 PM
  #55
Maroz2884's Avatar
Car: 1984 Z28 CAMARO
Do you know if it possible to use the T5 slave cylinder for the T56? My t556 is mounted up and im using everything from the lt1 except slave cylinder, master cylinder, and pedals.? let me know asap as i want to have my car running by today..
Old Oct 3, 2011 | 12:27 PM
  #56
Car: 89 Formula
Not that I'm aware. I imagine you may be able to do so with a t-5 bellhousing but I'm not sure of the dimensional differences if any.
Old Oct 3, 2011 | 06:42 PM
  #57
87350IROC's Avatar
Car: 87' IROC
Yes, the T-56 has a VSS.
Old Oct 4, 2011 | 02:05 PM
  #58
Car: 89 Formula
I should have read your post better.
The LT-1 T-56 uses a pull style clutch your T-5 slave cylinder is st up to actuate a standard push style clutch.
You could use your LT-1 bellhousing with the throw out bearing i mentioned above with a T-5 clutch.
If you wish to retain the pull style clutch you will have to use all LT-1 parts.
Old Oct 4, 2011 | 06:14 PM
  #59
Project-RS's Avatar
i have a question. can i run a t56 with a non ecu car? my 89 camaro was converted over to just a stripped down carbed car. no ecu, or power options. if there are kits, does anyone know of them, thanks
Old Oct 4, 2011 | 06:31 PM
  #60
87350IROC's Avatar
Car: 87' IROC
The T-56 does not require electronic controls for its general operations.
However there are a few considerations:
Is your speedometer electrically or mechanically controlled?
If electrical, you will need to use a VSS which the T-56 is ready for. If mechanical you will either need to run a converter box or have the tail housing machined for the cable.
The other is the reverse lockout. The T-56 uses a solenoid to prevent the shifter from going into reverse above about 10mph. Lots of people have lots of bad ways to get around this without the proper ECM. In my opinion and best, and most factory way, is to use the Samoco controller box, which unlocks reverse below 10mph, just like factory.
http://www.samocoind.com/T56Module.html
Old Oct 4, 2011 | 06:38 PM
  #61
Project-RS's Avatar
i have an autometer speedometer. mech one. thanks for the info. anything else i should need?
Old Oct 4, 2011 | 07:06 PM
  #62
Project-RS's Avatar
i also have a 1979 350 with 2pc rear main seal. if that helps
Old Oct 4, 2011 | 07:56 PM
  #63
87350IROC's Avatar
Car: 87' IROC
You will need a conversion flywheel since you have a 2pc rms engine. I think centerforce makes one.
Old Oct 4, 2011 | 08:01 PM
  #64
Project-RS's Avatar
thanks for the fast responce. making a parts list as we speak
Old Oct 4, 2011 | 08:45 PM
  #65
Project-RS's Avatar
heres the conversion flywheel http://www.summitracing.com/parts/CTF-700107/
Old Oct 4, 2011 | 10:18 PM
  #66
87350IROC's Avatar
Car: 87' IROC
Thats the one. Good move on the T-56. You will love it.
You will also need:
crossmember
brake/clutch pedal
clutch master cylinder and slave cylinder
shifter
5spd console plate
Old Oct 4, 2011 | 10:36 PM
  #67
Project-RS's Avatar
im going to get the spohn crossmember. does it matter on the master/ slave cylinders? the shifter i will probably go with a short throw one. as far as the 5 speed console, im having my already custom center console fitted for the t56.
Old Oct 5, 2011 | 06:00 PM
  #68
Project-RS's Avatar
any specific vss unit i should buy?
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
