88 t-5 trans fluid?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 88 t-5 trans fluid?
ATF was factory but lots of folks including a EX lead GM engineere says to use straight 30W oil [like he does]. ATF was done for MPG but is to thin but 80-90 is way to thick. Straigth 30W will flow well but offers better protection.
A good 30,000 miles and no complaints with it here........
I talked to Hanlon Motorsports 3 or 4 times during my T5 rebuild. Sure they sell Redline, and i realize the brand name doesn't necessarily make it better...
....but...he did say without a doubt that any brand synthetic dex/mercon was the way to go. Is that the ONLY way to go? Of course not. I've learned there isn't always one best answer, and everyone has an opinion, but I doubt Hanlon has fuel economy in mind.
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Bob Hanlon told me that if it is a WC transmission, using anything other than ATF will be bad for the blocker rings.
On NWC, he still recommends ATF, but you can use other lubricants without hurting the transmission.
maroe624
Apr 16, 2017 08:29 AM
