T5 Problems
Old Jun 22, 2010 | 09:10 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
T5 Problems
I have a t5 out of a 86 camaro. I just rebuilt my motor and put ram hd clutch and new pilot bearing, new flywheel, and all arp hardware. now here my problem if start the car and try to put it into gear i cant get it into gear so my buddy and i bleed the clutch but we did it wrong but i didnt know til i did research and found out how to bleed the clutch from http://www.teamrip.com/how_to_proper...utch_info.html so me,my girlfriend, and mom went out and bleed the clutch to the directions and now it grinds when trying to put it reverse and than when i try to put it in gear it makes the motor die down. any ideas?
Old Jun 23, 2010 | 12:42 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: T5 Problems
i just tried adjusting clutch pivot ball stud i turned it all the way in and back it out a little and still wont work.
Old Jun 23, 2010 | 02:31 PM
ckelton's Avatar
Transmission: T-5 Manual
Re: T5 Problems
I had some problems replacing a clutch in my '87 T/A. Honestly i just placed the clutch fork in the wrong position on the throw out bearing. This kept me from disengaging the clutch to where i could not get it into gear.
Wont hurt to pull the boot off to make sure that the whole clutch fork is in between the throw out bearing. I thought the thin metal (spring) went on the outside of the throw out bearing, so that it would not come off, well i was completely mistaken ha.
Old Jun 24, 2010 | 10:09 AM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: T5 Problems
thanks for the help ckelton but my throw out bearing is installed right.
called Ram Clutches and talked to there tech apartment and they said the throw out bearing isnt big enought being i got a hayes flywheel and the clutch and that i need to shim the flywheel or get adjustable throwout bearing. THan i called summit talked to there tech apartment and they said i had three choice slip the clutch for awhile ( cant do that wont go in gear), buy adjustable throwout bearing ( they said that might be a bad idea cause if i adjust it too much and can put the Bearing right thru the fingers), last choice take trans out and pull bellhousing and pull off pressure plate and put 3/8 washer between the flywheel and pressure plate.
Old Jun 25, 2010 | 12:51 PM
Vice04's Avatar
Car: 84 Monte
Engine: 355 Chevy HSR
Axle/Gears: 3.90 Ford 9"
Re: T5 Problems
My similar problem was I had the wrong flywheel. If you are using a "stock type" clutch, you want a Centerforce 700100 flywheel or the same type from another brand.
I was using a RAM stock type from Summit when I found mine. (the $100 one)
Old Jun 25, 2010 | 04:20 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
Re: T5 Problems
i got hayes 10-530 flywheel and when i talked to the tech dept. they said they been hearing a lot about people having same problem so i just order my shim kit be here monday,
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
