Th700r4, mount -93 internals into -83 core??
Old Jun 24, 2010 | 02:56 PM
Berghawken's Avatar
Car: 93 Camaro
Engine: lt1
Transmission: A4
Can i strip my cracked 1993 th700 and place all the internals, servo, 30spline shaft, and valve body in a 1983 core?
Visually they look the same except for some minor changes, even the aux valve body fits. same measures.
I know that you are supposed to look for a -87 and newer core but they dont come easy here in Sweden.
Old Jul 1, 2010 | 05:00 AM
Berghawken's Avatar
Car: 93 Camaro
Engine: lt1
Transmission: A4
Re: Th700r4, mount -93 internals into -83 core??
I didn't think i was so bad in english that no one would understand what i'm writing..
Are the housings/cases interchangeable, i would like to reuse all the parts that you can unscrew from the -93 housing.
Or should i consider this summer dedicated to jackstands while i look abroad for a newer housing?
Old Jul 1, 2010 | 11:51 AM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
As long as you also change the ft pump with all of the other hard parts it will work . Be sure to double check the valve body for alignmnet holse as improvement was also done there .
Let us know
Old Jul 1, 2010 | 12:23 PM
Berghawken's Avatar
Car: 93 Camaro
Engine: lt1
Transmission: A4
Let us know
Thank you Tx.
All the parts i'll take from the -93 transmission.
Only the aluminium housing i intend to use from the -83.
Old Jul 1, 2010 | 01:48 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
No the housings are not interchangeable. there are big differences especially in the valvebody area. the internal rotating parts are somewhat interchangeable but not all.
Old Jul 1, 2010 | 01:51 PM
Let us know
the 93 pump cannot be used in the older case. you will have a major internal leak.
Old Jul 2, 2010 | 01:49 PM
Berghawken's Avatar
Car: 93 Camaro
Engine: lt1
Transmission: A4
Is this something that is significant for the 93 pump or is it the same as all -87 and newer pumps?
I now have a empty(low/reverse piston is left) case from a -87 will this be better to transplant my -93 parts to?
The ID of the -87 is -7FAM if it makes any difference.
Old Jul 3, 2010 | 01:34 AM
the 87-up should be interchangeable, the only difference I can think of is the electrical plug in the case. 1 is a square 4wire the other is multi wire round.
Old Jul 3, 2010 | 12:33 PM
Berghawken's Avatar
Car: 93 Camaro
Engine: lt1
Transmission: A4
Ok Thank you, then i´ll start the assembly tonight.
I have the electrical plug from the -93 so that is not a problem.
Something that got me wondering is the measures of the low reverse piston.
The newer -93 is approximately 1mm higher(or 0.0393")
But it shouldn't be a problem since the rear planetary holder is mounted inside and the parking lever(not sure about the word here) still reaches and locks in the splines.
The newer part nr: 8685550-12 is to the right in the picture and the -87 is to the left.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
scottmoyer
Sep 7, 2015 07:06 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
