Convert turbo350/400 to 4 speed... hard?
Old Jun 26, 2010 | 09:16 AM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Im just wondering what is all needed to be done, just so im not guessing when i go to do this, i getting a super t10 4 speed, and i had a turbo 350/400 in my car, which btw if anyone wants to buy a trans, pm me.
Old Jun 26, 2010 | 09:49 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Convert turbo350/400 to 4 speed... hard?
Back in 1993,i did the opposite-switched my super t10
for a turbo 350-was an easy job:crossmember,driveshaft
torque arm were the same-just used aB&M torque arm
adaptor.If you can round up all the parts,350 to t-10
swap should also be easy The reason i took my t-10
out is because the shift arms had worked loose and
worn-causing it to "hang up"in two gears at once and
locking upand also the oil was gray indicating the
bearings were turning in the case.Years ago a 4-speed
hoarder got the tranny from me,but the rest of the parts
i kept and could look for if you cannot find any....
Old Jun 27, 2010 | 12:16 AM
Engine: 357
Hmm alright, well i basicly have a donor car, so i can steal everything related to the trans setup to throw on my car, and the trans is in great condition
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
