No 3rd Gear
Old Jul 3, 2010 | 12:02 PM
regular6d's Avatar
Car: 84 Z28, 05 Mazda 6
Axle/Gears: 3.42 Open
No 3rd Gear
So I rebuilt my 700R4 myself, everything was great for the first couple days, now I have 1st,2nd, won't go into 3rd, don't know about 4th the engine pretty much redlines coming outta 2nd and I don't wanna push it. Any thoughts? I checked the fluid, checked the filter and all that. Put about 120 miles on it since rebuild and not over 65 miles an hour or 2200 rpm until it decided not to shift.
Old Jul 4, 2010 | 10:46 AM
regular6d's Avatar
Re: No 3rd Gear
Gonna Pull the Governor and Servos out and see if it's in there, if not down with the Valvebody to check the checkballs hopefully it'll be that easy.
Old Jul 5, 2010 | 02:44 PM
JohnO.'s Avatar
Car: '84 Z28
Engine: 305 w/cam
Re: No 3rd Gear
Im having the exact same problem! only i put about 25 city miles before it decided not to shift into 3rd. have you come up with any solutions?
Old Jul 5, 2010 | 03:22 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: No 3rd Gear
i would have broke it in, maybe you have. sucks ether way
Old Jul 9, 2010 | 05:38 PM
regular6d's Avatar
Re: No 3rd Gear
I think I figured it out. I had a check ball in the wrong location, I set the trans up as an 84 because that's the year of the car but then I recently figured out the valvebody is from an 89, so now that I've got all that figured out I've just gotta get the TV cable hooked up at the carb, put the pan back on fill 'er up and hope I'm one lucky **** that didn't destroy the 3-4 clutch pack.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Warlocksirix
Sep 3, 2015 12:26 PM
suzuki949
Aug 28, 2015 08:07 AM
redmaroz
Aug 16, 2015 11:40 PM
