Trans mount every year
Old Jul 10, 2010 | 08:37 AM
timespy's Avatar
Car: 91 RS Convertible
Engine: Soon to be swapped
Transmission: Memphis performance 700r4
Axle/Gears: Soon to be changed
Anyone else have issues with trans mounts going bad every year. I have had this 91 drop top for about 5 years now, and every year I have had to replace trans mounts. This isnt some super high hp 305, just a basically stock motor with as many performance bolt ons as I could find. This trans is pretty much on its way out, and the motor is being replaced as soon as its cool enough to open the garage doors again. My concern is that once the new 350 is dropped in, and the trans is rebuilt, the car will be pushing twice as much hp, and tourqe. Seems to me the mounts will fail even sooner. The little 305 is a very tourqey motor, but come on..every year??? I checked the threads on the trans, and they are not stripped. I have bought the so called best mounts I could find. Even had a trans shop do the work once. Same thing, the back mounts loosen up, and wear away to nothing. Yes ive used locktite, and lockwashers. Any thoughts here? I dont want to break something after doing all this work.
Old Jul 10, 2010 | 11:41 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Trans mount every year
get a torque arm setup that relocates the front of the arm to something other than the tail of the trans.
Old Jul 10, 2010 | 11:42 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
I'd check to see if the mount is under stress first then I would check the motor mounts to see if they are bad.
Old Jul 11, 2010 | 01:35 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Put in a poly one, problem solved.
Old Jul 11, 2010 | 09:52 PM
I've torn 2 poly mounts due to bad motor mounts so problem is not neccesarily solved
Old Jul 12, 2010 | 10:21 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I agree, I would check the motor mounts, my guess is they are bad as well.
Old Jul 13, 2010 | 12:00 AM
jmd's Avatar
jmd
http://www.hawksthirdgenparts.com/ca...smember-1.aspx
Not that you couldn't go w/ an aftermarket tq. arm too...
Old Jul 13, 2010 | 11:24 PM
I love spending other peoples money
colton_carlson
Mar 8, 2019 12:21 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
