"EM" spacer plate? 700R4 92'
Car: 92 1LE B4C
Rebuilding the 700R4 out of my 92 1LE/B4C Camaro. Both Accumulator springs broke and banged up my valve body spacer plate a bit. But, I can't find its "EM" code in any of the my books or local trans part store. Anybody know anything about the "EM" spacer plate? Should I just replace it with a universal Trans Go spacer plate?
Car: `86 SS / `87 SS
Re: "EM" spacer plate? 700R4 92'
Some rebuilders put their initials in their work.
Dealer might have one for a '92. Compare to the one you have & you'll be good to go.
Car: 92 1LE B4C
I think I can just use this 77754HD corner plate, and cold work the spacer plate flat.
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
That looks like it might work but since your that far in.....you might as well just put a new spacer plate in. I have a 92 RS also and used the TransGo spacer. It worked fine. Just make sure you order the gaskets also. Mine didnt come with them and I had to order them. Good luck and dont loose your ***** lol
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
