Socket stuck inside of pilot bearing in engine
Old Jul 30, 2010 | 01:09 AM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
I was searching around for methods on removing pilot bearings since I would be using a 700R4. Well found one that was pretty straight forward and required normal household tools. So I start driving the socket in there with an extension and go to pull the extension out and it did just that. Socket is flush inside the pilot bearing. I can take the extension, put it back on the socket and put a ratchet on it and it turns inside the bearing with a little force, but it does. Not coming out though. What can I do to get this thing out!! I've heard of a tap or a easy out? Somebody help!!!
Old Jul 30, 2010 | 08:12 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Socket stuck inside of pilot bearing in engine
If the socket is turning, a tap/easy out probably won't work. You might insert a right-angled pick and attempt to wiggle the socket free.
JamesC
Old Jul 30, 2010 | 08:15 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
There's always the old trick of packing it FULL of grease, then hammering an extension into the socket. That'll drive the socket out.
Old Jul 30, 2010 | 10:35 AM
An extension that will go through the inside of the socket to the back of the crank or an extension that will fit into the socket?
Old Jul 30, 2010 | 10:36 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
A locking extension (that locks the button out so that the socket cannot come off) seems like something to try.
Old Jul 30, 2010 | 10:46 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The correct size for the socket, otherwise it won't work. You may have to top off the grease a few times.
Old Jul 30, 2010 | 01:36 PM
Got the socket out!!! Took a screw and beat it into the socket, took a long pry bar and got behind the bolt head and started prying. Popped right out
red90IROCls1
Aug 25, 2015 06:56 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
rsrmoore
Aug 7, 2015 08:44 PM
