T56 starter choices?
Old Aug 24, 2010 | 12:54 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
In the middle of an L98/ T56 swap and i was wondering what kind of a starter i'll be needing, not sure if i can just reuse the one from my 305 TBI, i mean im not sure of the tooth count on the flywheel (fidanza from wesilva) because its being shipped and i also dont know the depth because i dont know if the t5 has a different distance than the t56, id like to go with a stock starter for money, unless i can find a mini starter for close to the same price (might as well lol)
Any info would be greatly appreciated
TIA
Old Aug 24, 2010 | 10:25 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Re: T56 starter choices?
The only thing i can tell you is that when i went from a 700r4 to a T-56 i had to get an LT1 starter b/c its a 153 tooth flywheel and i think the 700r4 flexplate was like 164 or something. Idk about T-5 to T-56. Sorry i'm not much help...
Old Aug 24, 2010 | 10:58 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
That helps with the tooth count, I should be good with an lt1 style starter
Old Aug 24, 2010 | 11:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Try your 305 starter. Get an LT1 starter if it doesn't fit.
All 82-97 V8 F-bodies were 153 tooth flywheel / flexplate.
Old Aug 25, 2010 | 12:17 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Ill compare the bellhousings when I get a chance if they're the same tooth count I don't see why it wouldn't work, although the t56 does sit back a bit further... its worth a shot I suppose lol I'm just not sure if the extra length comes from the bellhousing or the 6th forward gear, or even a combination of both
Old Aug 25, 2010 | 12:56 AM
jmd's Avatar
jmd
I just remembered - I have a 305 starter with an LT1 bellhousing in my car.
Old Aug 25, 2010 | 01:08 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
HA WIN! lol money saved is always a plus
Old Aug 25, 2010 | 05:32 AM
v10viper04's Avatar
Engine: LT1, L99
If that was true then why did i need to change my starter? The original sat too far out... Or do you mean all 82-92 manuals?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
gixxer92
May 18, 2017 11:20 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Vincent135
Sep 28, 2015 10:50 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
