shift linkage cable removal/disconnection?
Old Aug 26, 2010 | 05:22 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Pulling trans and its probably a dumb question but how do I disconnect the shift linkage cable from the transmission, just being really cautious about everything...I can't afford another mistake..
Old Aug 26, 2010 | 09:23 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: shift linkage cable removal/disconnection?
You have a 13mm nut that connects the linkage to the tranny gear selector. Then you have 2, 10mm bolts that hold the shifter bracket and pass thru the trans pan. Remove all these and your speed sensor wires.
Old Aug 27, 2010 | 03:10 PM
Engine: 3.8, 3.4
Got the trans out, and actually all 3 bolts were 13mm on mine, but how do I know what position to reinstall the selector in to match the shifter in the car?
Old Aug 27, 2010 | 03:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Put the shifter and the shaft on the transmission both in neutral and then bolt up the cable.
Old Aug 27, 2010 | 03:25 PM
Engine: 3.8, 3.4
How exactly do I know if the shaft on the trans is in neutral or not? I'm pretty green when it comes to transmissions...
Old Aug 27, 2010 | 03:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Rotate it by hand and count the detents.
Old Sep 5, 2010 | 08:38 PM
Engine: 3.8, 3.4
Um...still need more specific, the thing moved god knows how many times when I was unbolting it, do the spots on it correlate directly with the console shifter, like all the way forward with the linkage on trans is park? and all the way towards rear of car 1st?
Old Sep 5, 2010 | 09:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
camaronils
Sep 20, 2015 02:57 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
tonys91rs
Sep 2, 2015 07:07 PM
