2.8l Hydaulics (master and Slave sylinder) fit a V8 set up?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
My headers just burnt through mine and the local junkyard has one with a 2.8l. So My question is, will I have any problems using a 2.8l master and slave cylinder in my V* set-up? PLease answer ASAP!
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: 2.8l Hydaulics (master and Slave sylinder) fit a V8 set up?
I believe they are the same.
The other option is to buy it online. I bought my master cyl from AdvanceAutoParts online and used the coupon code A123 and saved $20 from the order. You might try that and get new for much cheaper and not have to use the used stuff...
They're the same... The clutch hydraulics don't know if they're mounted to the bellhousing on a V8 or a V6.
the_hamturdler
Sep 30, 2015 12:50 PM
