either a tk0 600, t56, richmond,stock t5 need to make find the best setup
Old Sep 15, 2010 | 10:16 PM
ryguy1989's Avatar
Car: 1989 pontiac firebird formula 350
Engine: 350 stock but not for long
Transmission: 700r4 but swap to manual
i got a stock 350 formula with a blown 700r4 want a manual and have a wct5 parts car but am going to build the motor so wanted a good trans. need some good info and advice
Old Sep 15, 2010 | 10:46 PM
DSGx's Avatar
Car: 92 Pontiac Firebird
Engine: 305 TBI L03
Axle/Gears: 2.73 one wheel drive
Re: either a tk0 600, t56, richmond,stock t5 need to make find the best setup
i think a t-56 is what ur looking for, or u can beef up the t5 but getting a t-56 is just way better.
Old Sep 15, 2010 | 11:14 PM
ryguy1989's Avatar
i did see that the t56 was heavy compared to the tko 600 but i want to find out how the tko shifts, smoth or rough.the t56 hast to be out of a lt1 right to fit the l98 block.
Old Sep 16, 2010 | 07:57 AM
DSGx's Avatar
Engine: 305 TBI L03
The ls1 cars used the same tranny if im not mistaken , the back part of the motor is the same between LS engines and our old smallblock design. Correct me if im wrong im no expert.
But rly , if u want a nice manual tranny, get a t56 . If u can get one from an lt1 then go ahead , like i said im no expert so i dont know if ls1 t56s had same bellhousing bolt pattern.
Old Sep 17, 2010 | 07:31 AM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Ls1 is different, lt1 is direct fit.
T-56 is a good trans. If you want it built get a viper spec one.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
