T5 shifter wobbling, Please Help!
Car: 1992 Camaro RS, 2012 ZL1 on order
Engine: 5.0 305, 6.2 Liter LSA SC
Transmission: T5, TR6060
Axle/Gears: stock, 3.73
So yesterday I started driving down my street and my shifter started wobbling up and down through all of the gears when I accelerate faster than the average driver. Does anyone have any suggestions? I checked the trans mounts and they seem to be tight and in place. Also,(this isn't a new issue),my clutch pedal stiffens up when i don't use it for a while, like driving down the freeway. Any suggestions will help, thanks alot
Re: T5 shifter wobbling, Please Help!
Not sure what "mounts" you checked; but if there were more than one thing, they weren't the transmission mount.
You need a transmission mount, same as every other one of these cars. I'd recommend not getting a stock replacement. Get a poly one instead. Speaking strictly for myself, I could back my car down the driveway and rip a stock mount in half the VERY FIRST time I let out the clutch. Did it once in fact. Now granted my car had a good bit more power than yours, even then (it was still stock); but still. That tells you how over-stressed the mount is in these cars.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
yeah stock mounts suck, i ripped 3 of them in a week before buying my poly one lol its on the crossmember between the tailshaft and the Xmember, like 4 bolts to drop the member, and i wanna say 3 on the mount itself
ya, thanks alot, i know where it is located. I have done quite a bit of work on it...too much. Just trying to piece it together so I can sell it and get my 2002 SS. Thanks for your help
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/atta...ber-mounts.jpg
Should the OP be interested in poly, the following link might be an interesting read:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
You know that saying you llearn something new everyday? JamesC gets another point for it lol
Thanks alot everyone, it seems it was the transmission mount. I went with a prothane and that fixed it pretty well.
