tranny from a 82 berlinnetta into a 88iroc-z
Car: 89RS-5.0/88IROC-Z-5.0/92-5.7 z28/v6
Engine: 5.0/5.7/2.8
Transmission: 5 spd in two stock auto in other tw
Axle/Gears: stock
MY QUESTION IS will a automatic transmission from a 1982 berlinetta with the 305 V8
fit into a 1988 iroc-z with the overdrive transmission and the 305 TPI
Re: tranny from a 82 berlinnetta into a 88iroc-z
It's not a 700R4, if that's what you're asking. "Fit" as in it'll physically bolt in, it might if you have every piece, including the crossmember and the driveshaft. But really, why?
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
It won't live long, it's not a strong tranny at all.
Engine: 5.0/5.7/2.8
Axle/Gears: stock
theres an 1982 berlinetta i can get for 400$
my dads 88 iroc-z hasnt gotten out of 2nd in 3 years
my car just hit a pole i was gonna buy the berlinetta for parts(fenders,hood.nose) is their anything i could do to make the tranny in the berlinetta strong enough to with stand the iroc
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
standard automatic used on the '82 v8 cars was the
3spd th200c it might hold up,might not-'82 up versions
were improved some,but still considerd weak for v8
usage they can be upgraded as a lot of the internal parts
are shared with the 4spd th200 4r which can be built
to handle over 500hp. The 82 tranny could be installed
in the '88 using parts from the berlinetta parts car,but
it would be far easier to just fix whatever is wrong with
the 700r4 in the '88,not to mention the 700r4 is a
better tranny...
better tranny...
Engine: 5.0/5.7/2.8
Axle/Gears: stock
my dad says that any mechanic that rebuilds trannys will fuc* it up since he has had it done twice once in the camaro and once in a acura legend so he doesent trust that( A SHIFT KIT OR SOMETHING LIKE THAT WOULDENT GIVE IT WHAT IT NEEDED?
but i owe him 700 dollars and he said if i give him a tranny that could swap out for his we would be square and i wouldent owe him anything since i need fenders,hood,and nose off this car i thought i might as well get the tranny out
but you think that someone could rebuild one of these trannys using both the parts since they are similiar
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
