4L80E Swap
Old Apr 25, 2011 | 08:56 AM
  #101
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
Re: 4L80E Swap
I absolutly hate my Lokar, to the point of making and access hole and a short tube directly above the port on the trans.... You can't read the lokar after you put some in.... and it take forever to pour it in... hate it... is there a trick for these problems... jesss
Old Jun 1, 2011 | 08:31 PM
  #102
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Re: 4L80E Swap
here are a few pics of how I did mine.
Attached Thumbnails 4L80E Swap-hpim0610.jpg   4L80E Swap-hpim0621.jpg   4L80E Swap-hpim0620.jpg
Old Jun 25, 2011 | 05:38 PM
  #103
dozerjoe's Avatar
Re: 4L80E Swap
did bmr ever contact anyone with a solution. i havent heard a thing from them
Old Jul 2, 2011 | 10:41 AM
  #104
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Re: 4L80E Swap
I wish someone provide some kinda update. Im curious how this turned out.
Old Aug 17, 2011 | 04:04 PM
  #105
JAYDUBB's Avatar
Car: 1991 Camaro RS
Re: 4L80E Swap
Can someone PLEASE for the love GOD update the status on this? How did the BMR trans mount work out?
Old Feb 13, 2012 | 10:59 AM
  #106
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Re: 4L80E Swap
Bumping this as I'm about to do mine. Will be using a custom mount setup though. What driveshaft did you guys use.
Old Feb 13, 2012 | 11:34 AM
  #107
jonarotz's Avatar
Car: 91 Z28
Re: 4L80E Swap
I am using a stock length spohn driveshaft.
Old Feb 13, 2012 | 12:53 PM
  #108
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
Re: 4L80E Swap
Had a local shop make mine.
Old Feb 13, 2012 | 02:56 PM
  #109
Grifter757's Avatar
Car: 87 IROC,
Transmission: 4L80E
Re: 4L80E Swap
HHmmmm, I might just get a custom peice from PST as I'm pretty sure the aluminum one is not going to cut it.
Old Jul 13, 2012 | 02:33 AM
  #110
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: 4L80E Swap
jonarotz
Thinking about swapping 4l65 or 60E instead rebuild another 700 again my trans is acting up only drives in D and acts like neutral in [D] 2nd one in 2nd thidgen and this one only has 3000 miles on it
Just venting but back on subject on hand..
so a couple questions
4l80e is longer then 4l60e/65e ?
Driveshaft Modification need with 4l60e/65e ?
Is it a direct bolt up to L98 TPI or 1st Gen SBC to be correct ?
To control trans i was thinking EZ-TCU or SIMPLESHIFT
i have pretty mild engine l98 bolt ons cam and soon 1.6 rockers lt1 intake nothing special
plan to swap lq9 later down the road no rush tho
and how hard does your trans shift with the trans go ie crisp hard violent does it chirp the tire in 2nd
If i miss those answers in the tread ill read again its late so reading not too good ill read again in the morning thank you!!!!!
Old Jul 18, 2012 | 09:48 PM
  #111
jonarotz's Avatar
Car: 91 Z28
Re: 4L80E Swap
The length difference is very minimal if I recal. The biggest problem is mount location is further back.
You will need to put a different slip yoke on the driveshaft. The 4L80E has a larger output shaft.
The trans go kit is very nice, no banging just really crisp and firm.
It will bolt right to your small block.
I use a TCI controller for mine.
Old Jun 14, 2013 | 04:18 PM
  #112
JAYDUBB's Avatar
Car: 1991 Camaro RS
Re: 4L80E Swap
Bump from the deceased... Can anyone say what crossmember they used/made to get the 4L80E to fit?
Old Jun 14, 2013 | 06:31 PM
  #113
Pocket's Avatar
Car: 91 Trans Am
Re: 4L80E Swap
Totally custom
Old Jun 14, 2013 | 07:56 PM
  #114
jonarotz's Avatar
Car: 91 Z28
Re: 4L80E Swap
Built my own custom one.
Old Jun 19, 2013 | 09:24 PM
  #115
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: 4L80E Swap
I had to build mine, Angle Iron and rectagular tubing. Hey Jonarotz, Quick question. I see you had a bolt on yoke on your 4l80e. Did you have splines all the way down? Or half way? How much splines you hav in contact with yoke? 2 or 3"?
Old Jan 2, 2014 | 12:09 PM
  #116
86mailman's Avatar
Car: 86 Iroc
Engine: 496
Transmission: 4l80e
Axle/Gears: 9" eaton posi 4:11
Re: 4L80E Swap
Originally Posted by jonarotz
Well I got the transmission put in tonight and I must say that it is heavy! Here are some pics of it installed. I still have to finish welding the X-member but thought I would share.
im doing the same swap. i just hollowed out my 700r4. where did you get your computer to run your 80e from.i have an 86 iroc with a 505. any information on this swap will be grately appreciated.
Old Jan 2, 2014 | 12:50 PM
  #117
jonarotz's Avatar
Car: 91 Z28
Re: 4L80E Swap
I am running a TCI controller and I like the ability to program it the way I want it. I have a spare one that I have been trying to sell if you're interested.
Old Oct 2, 2014 | 02:29 AM
  #118
408irocz's Avatar
Re: 4L80E Swap
Is the controller still for sale?
Old Oct 2, 2014 | 07:37 AM
  #119
jonarotz's Avatar
Car: 91 Z28
Re: 4L80E Swap
No it was sold a while ago.
Old Oct 2, 2014 | 05:40 PM
  #120
89CamaroProject's Avatar
Car: 89 Camaro RS
Engine: 2.8 (soon to be 350)
Re: 4L80E Swap
ok, ive been looking around and i cant find a straight answer, im trying to use a 4l60e from a suburban with a vortec 350, im converting the 350 to carbed but i want to keep the 4l60e because its an awesome trans, i know you have to do something with the pcm, but im not sure what, im looking for a cheap solution and any advice would help. thanks! im looking to throw the combo into my camaro.
Old Oct 2, 2014 | 06:42 PM
  #121
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 4L80E Swap
How much farther back is the trans mount on the 80 compared to the 60??
I'm wondering if the TTA trans crossmember would work.
Old Aug 11, 2015 | 07:56 PM
  #122
steve40's Avatar
Re: 4L80E Swap
i'm curious what shifter you are using and if you had to modify the linkage on the trans?
i'm having some problems where if i set the cable when in park, i can't get into 1st, and vise versa if i set it in first it won't go into park.
the linkage i have on the trans is from the vehicle the trans came from. it measures 2.25" center to center for the cable to rod on the trans. unfortunately i don't have that same linkage for a 700r4 out of a 3rd gen, not sure if it's the same length or not.
Old Aug 12, 2015 | 07:48 AM
  #123
jonarotz's Avatar
Car: 91 Z28
Re: 4L80E Swap
I used my stock shifter for a while, but I had to make a custom bracket. I now run a B&M Megashifter and it seems to work just fine.
Old Aug 12, 2015 | 09:02 AM
  #124
steve40's Avatar
Re: 4L80E Swap
Ok, did you use the stock arm from the 700r4? Maybe the length of that is different from the truck one I have.
Got any pics of the mount?
Old Aug 13, 2015 | 11:37 PM
  #125
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: 4L80E Swap
I also run a B&M Megashifter, but below is the shifter arm I'm currently using. It was modified from a 4l60E shifter arm. The 2 1/4 hole is what this arm used on the original (4l60E vehicle). The 1 7/8 hole is what is being used on the Camaro.
Using the "Best" geometry shown below the maximum radius your compatible shifter arm could be estimated by R=Total length of cable travel / (2*sin[45 degrees])
Just noticed I misspelled function, oh well, you get the idea.
Old Aug 27, 2015 | 12:17 PM
  #126
0078red1's Avatar
Car: 1990 camaro RS
Engine: 1998 ls1. 5.7L
Axle/Gears: 4th gen rear end for got the gears
Re: 4L80E Swap
Anyone using longtube headers with there 4l80e swap with an Ls?
Old Mar 28, 2017 | 09:32 AM
  #127
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: 4L80E Swap
For those of you that LS swap....you can use this cross member with the 4L80 adapter. The only down side is you have to use their respective motor mounts. You can use a factory size torque arm.
https://www.holley.com/products/exha...ts/71222005HKR
Old May 9, 2017 | 10:37 AM
  #128
Ozz1967's Avatar
Car: 1984 Trans Am
Re: 4L80E Swap
Using the Holly Blackheart Headers with the Holly Motor mounts and Trans mount you can run long tubes with no issue.
Old May 9, 2017 | 10:51 AM
  #129
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: 4L80E Swap
i'm using a 4L80E crossmember from PA Racing. fits great. only had to slightly massage two spots in the tranny tunnel. i'm also using a BMR trak pak torque arm setup.
Old Jul 30, 2019 | 09:47 PM
  #130
1990_iroc-z's Avatar
Re: 4L80E Swap
Attachment 315092
Attachment 315093
can you tell me what kind of motor mounts are you using ?
can you run long tube headers with the PA RACING cross member?
what kind of drive shaft and yolk ?
Old Jul 31, 2019 | 07:01 AM
  #131
battmann's Avatar
Re: 4L80E Swap
I’m using UMI’s solid motor mounts and their LS swap mounts. Not sure about long tube headers as I’m using forward facing turbo headers. I also don’t have a driveshaft yet. I need to get the car more put back together for weight to take measurements. Planning to order a custom driveshaft from Denny’s.
Old Aug 1, 2019 | 06:19 PM
  #132
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: 4L80E Swap
I'm using long tube headers with the pa racing crossmember but with a sbc, not an ls motor. My driveshaft had to be shortened to 39.5 inches from the stock 42 inches because of the yoke i used. Some 4L80e/T400 yokes are long and some are short. You need to pull off your tail housing on the trans to see which yoke you need.
Old Mar 6, 2023 | 10:14 AM
  #133
frankensteinGTA's Avatar
Car: 89 GTA
Engine: 94 LT1 with Painless Perf. cam kit
Transmission: 700r4 2100 stall conv. Vette servo
Re: 4L80E Swap
Next up is the cable bracket. It looks like I need to move this back 3/4" from the pan bolt in the pic. I am going to work on this tomorrow. I think I may make slotted holes to allow for some more adjusting.
Not sure this thread is still active but will try anyway. Am doing the same swap (4l80 into 3gen firebird) and having a heck of a time with the shift linkage. Original for the 700r was too long so bought a Shift works cable which is also too long. Trying to use the original shifter/gear selector. What did you end up using for a shift cable?
Thanks.
Gb
Old Mar 6, 2023 | 10:26 AM
  #134
battmann's Avatar
Re: 4L80E Swap
Not sure if there’s a way to reuse the original shifter and cable. I’m using a B&M megashifter made for our thirdgens. The kit includes a new cable and couple brackets you attach to the transmission.
Old Mar 6, 2023 | 10:32 AM
  #135
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Re: 4L80E Swap
I'm using the shiftworks cable just fine. It is adjustable so that helps. Take a pic of your alignment. I did have to slot my bracket where it attaches to the trans pan bolts to get it aligned.
Old Mar 6, 2023 | 12:29 PM
  #136
Car: 89 GTA
Re: 4L80E Swap
Appreciate the feedback. Which b&m megashifter did you use Battmann? Pricey units but they do jazz up the consul a bit.
89gta383, probably don't have a record of which shift works kit you used do you? To make mine fit it had to be routed towards the back of the car and then forward again to take up the slack. Sort of a "S" shape. All this did was make it bind up and not function.
Old Mar 6, 2023 | 12:36 PM
  #137
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Re: 4L80E Swap
https://shiftworks.com/collections/c...27877042192467
I used the one for 82-92 fbodies with a 4l80E.
You will see in the picture the bracket is different. On the website, toggle between the one for the 700r4 and the one for the 4L80E and you will see the bracket differences. Call them and see if the cable is the same length between those 2 kits?
Old Mar 6, 2023 | 02:04 PM
  #138
battmann's Avatar
Re: 4L80E Swap
This is the B&M one I have. The price definitely went up in the past few years since I bought it.
https://www.holley.com/products/driv...er/parts/80692
Old Mar 6, 2023 | 02:41 PM
  #139
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: 4L80E Swap
I've got that one too it works great
Old Mar 18, 2023 | 10:51 AM
  #140
Car: 89 GTA
Re: 4L80E Swap
Yes I am running the same driveshaft as I was. I did have to change the slip yoke because the 4L80E has 32 splines and is quite a bit bigger.
This is a great thread. Appreciate all the info. Do you remember what slip yoke you used? Doing this same swap.
Gb
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
