Stock 700R4 auto shifter differences?
Old Sep 19, 2010 | 12:12 AM
n1ffer's Avatar
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
Hi - couldn't find this in other posts, so hopefully not a redundant question.
I noticed while installing a new stereo and had my auto console shifter cover plate off that there were two cables coming from the floor toward the shifter.
One is the shift cable, the other I assume is the ignition lock cable. The one I believe is the ignition lock cable was not hooked up.
I hooked it up to a spot on the shifter that looked like where it should hook up, but pushing in the parking release button on the handle was extremely difficult after doing this, almost like the cable was stretched as far as it could go.
With this cable off the shifter will shift into gear when the ignition is off and the button pushes in very easily.
My question is - are there different shifter mechanisms for the '83 Trans Am than maybe the later models? I have a few extra shifters that came with the car that look slightly different than what is in the car, but they are broken and I can't install them to check for differences.
In a nut shell, are there different shifters for the earlier T/A 700R4 set ups than the later models, or is my cable just needed to be pulled through the floor and adjusted better?
Old Sep 21, 2010 | 11:21 AM
n1ffer's Avatar
Axle/Gears: 3:23
Re: Stock 700R4 auto shifter differences?
Guys - any help? is the 83-84 700R4 shifter different than the 1985 and up third gens?
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
NBrehm
Aug 25, 2015 11:49 PM
Leggman1
Aug 6, 2015 04:15 AM
