torque convertor not locking up
Old Sep 19, 2010 | 09:01 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
I am trying to wire in a toggle switch to lock up the torque convertor on my 700r4, but i want to be sure that I get it wired correctly. The tan/black wire and the blue (or green) wire have 12V with the ignition on. Do I need to ground the purple wire to get the torque convertor to lock up?
Old Sep 20, 2010 | 12:43 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: torque convertor not locking up
It depends on the switch that YOUR particular transmission has in it - you have to test it to see if it's normally open or normally closed. If you have the right switch inside the tranny, then you can lock with a toggle. If you have the wrong switch, then it's implied that you cannot without replacing that internal switch.
There's also been talk of leaving the ECM in tact and plugged up, and just locking the TC through the ALDL connector - but I've never read where anyone actually did it this way.
Here's the tech article if it helps: https://www.thirdgen.org/forums/carb...c-control.html
Old Sep 20, 2010 | 01:40 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Ok, thanks! Nowcan anyone tell me what color wire corresponds with pin D and pin B on the connector?
Old Sep 20, 2010 | 07:49 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
maybe i should go about this a different way. After thinking about this whole thing, i would much rather have my torque convertor lock up utilizing the original system. It should be working and I'd like to figure out why.
Old Sep 23, 2010 | 08:44 PM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Alright, does anyone have a wiring diagram for the C100 and C207 of my 87 GTA (LB9)? I also need the ECM wiring diagram for an 89 Firebird (L98). I believe I have a few loose wires under the hood by the firewall that are left open from my engine swap. Thanks!
Old Sep 23, 2010 | 11:29 PM
Car: 1992 RS
Engine: Carbed 350
Just about all wiring diags here: http://www.austinthirdgen.org/index.php?pid=19
Old Sep 24, 2010 | 07:06 AM
stealth908's Avatar
Car: 87 GTA
Engine: tpi 350
Yeah, I tried to use those when I installed my motor and transmission, but most of those are for Camaro's. The ones for Firebirds are different, I think. Either that, or my car is wired differently than other Firebirds. Thanks for helping!!!
Old Sep 24, 2010 | 09:25 PM
Car: 1992 RS
Engine: Carbed 350
The major items should be all the same on the wiring for both connectors. The C207 ought to be identical, thats ALL ECM functions which is not different between Pontiac and Chevy (since Pontiac hasn't made anything on their own since mid-1970's). And the C100 - the only differences would be for a few minor things like extra pinouts for the wires to the pop-up headlights maybe.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Nervous2
Oct 8, 2015 10:53 PM
Nick McCardle
Sep 10, 2015 08:36 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
