383 stroker questions
Old Sep 20, 2010 | 04:39 PM
RRoot9491's Avatar
Car: 91 Firebird Formula T-Tops
Transmission: 700-R4
Does anyone know if the 700R4 trans will hold up with a 383 stroker in a 91 firebird formula?
Old Sep 20, 2010 | 04:50 PM
Killerz187's Avatar
Car: '91 Camaro RS T-Top
Engine: 383 Stroker
Transmission: Bulldog 700r-4
Re: 383 stroker questions
Wrong section for this type of post.
It depends. If your tranny is in good shape, and you don't abuse it, it'll last.
But if you have drag tires, and like to launch it hard every single time it'll fall apart on you very quickly.
If your tranny has high mileage, consider rebuilding it and adding a good shift kit+ 'Vette servo to it. Might as well shell out the money on your tranny as well, before it gets super expensive.
Old Sep 20, 2010 | 08:17 PM
RRoot9491's Avatar
okay where would i post this then, i just became a member today, i find it kind of confusing to navigate. Anyways the tranny has 113,000 on it and by the time i rebuild the 350 and am ready to drop it in it will have a lot more. its an everyday car as of right now but i hope to buy another vehicle so i can garage this one. It has a shift kit now but ill have the tranny rebuilt and am thinking of putting 3.55s in the rear.
Old Sep 20, 2010 | 08:43 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You would post in the "Transmissions and Drivetrain" section.
Are not 3.55 ford gears ? Are you going to a 9" ford rear end?
Old Sep 21, 2010 | 02:07 PM
RRoot9491's Avatar
no im stayin with gm. what would be gm's ratio then instead of 3.55s. 3.42s? also do you know if a stage 1 chip for around $150 from jegs would be beneficial or a waste of money for a 5.0tpi 91 formula?
Old Sep 21, 2010 | 02:11 PM
383tpimachine's Avatar
Car: Corvette
Engine: 383
Axle/Gears: D36 w/ 3.08
3.54 is a GM gear.
skip the chip. Just get a custom one made when you drop the new engine in.
Te 700r4 can last as mine has under 400rwhp. No problems yet. I plan on building one for my next 383 when Im looking for 450rwhp and a very broad curve.
Im more afraid of heat as this is a roadrace car so get a trans cooler and be happy
Old Sep 21, 2010 | 02:16 PM
RRoot9491's Avatar
okay thanks. appreciate it
Old Sep 25, 2010 | 02:55 PM
RRoot9491's Avatar
Where do you go to post i new thread its so *** confusing. does anyone know if a 150 dollar stage 1 chip from jegs would be worth it or no?
Old Sep 25, 2010 | 04:40 PM
Car: Corvette
Engine: 383
At the top of a desired section it has a tab that says "New Thread"
as for the Chip dont get one. Get a custom one for YOUR application. Each engine responds differently so it needs to be custom tailored to your car
Old Oct 4, 2010 | 07:49 PM
RRoot9491's Avatar
okay thanks a lot appreciate it
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
bdads
Aug 24, 2015 06:01 PM
redmaroz
Aug 16, 2015 11:40 PM
