best gear ratio?
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
best gear ratio?
I have an l98 350, with a t-5 5 speed. Currently, I have 4.10 gears, but was wondering if a 3.42 or 3.73 would be better. I know the 4.10 are better for torque, but I want acceleration and speed balanced. Any recomendations?
Re: best gear ratio?
what i was thinking, with 4.10s i think that driveshaft just has to spin too much for the wheels to turn, good for torque, but not the best for speed, somewhat...lol
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
4.10's arent anywhere near good especially since you look to have a stock 350 tpi. Those motors run out of steam in the blink of an eye.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
4.10 may be good for stoplight to stoplight driving but even with an overdrive, it's too deep for the 26" tires on the highway. 28" tall tires and 4.10 with an OD can handle highway speeds easier.
2.77 gears would suck for performance on the street but the engine would be idling at highway speeds.
"Best gears" depends on what you want to use the car for. For day to day mixed driving, mid 3.xx is a good ratio. For mainly highway driving, mid to high 2.xx. For drag racing, whatever gear allows the engine to max out it's rpm as you cross the finish line in high gear (not OD).
Engine: gone
Transmission: gone
Axle/Gears: gone
I have heard TPI saying they ran quicker 1/4 miles with 3.23's over 3.42's and 3.73's. I run 3.42's in my camaro I think depending on tire size its the happy medium for take off power and top end speed. as well as fuel mileage and etc. I know I get to drive in the 1/4 mile a couple hundred feet before the traps. when the engine is still pulling. But you really wanna be topping out for optimum performance right before you go through the traps.
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
In my opinion as you start to upgrade your motor or swap you will want a higher gear ratio to get better E/Ts.To answer your question, With your setup I think 3.73's would be good or even 3.42's. You could get a taller and wider tire to give you some more traction and less spin off the line and in some cases more speed down the line. Alky is right these motors stock do run out of steam fairly quickly.
I would stick with the 4.10s if your planning on doing motor work do it and get a taller/wider tire.
When I went from a 235/65/r16 to a 275/45r18 they handled the power and 3.73 rear much more efficiently.
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I run 3.42's and they're still tolerable for the highway. 4.10's are overkill on a stock motor in my opinion.
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
i have the same question here...3.73's or 4.10's???..i have a L98 TPI 350 with bbk underdrive pulleys, afpr, headers, and a built 700r4 everything else is stock and original..the 3.73's are looking good once i came into this thread. i was thinking of going with 4.10's but u all are pretty much showing how 4.10's arent really good for a pretty much stock TPI..so 3.73's would be my best option?
Car: 1985 IROC-Z
Engine: 355
Depends on how you drive your car and what your plans are. Are you going to keep it stock and is it a DD. If it is I wouldn't do any more than 3.73. If you plan on racing at the strip and using larger tires with higher HP I would go 4.10s.
Car: 1985 IROC-Z
Engine: 355
0.63(TBI) 0.74(TPI) Are the ratios in the Borg Warner t5. Sorry I was still thinking about robg91z question.
Engine: 350ci TPI
well the mods i have posted it wat i have for now..thinking of getting some heads and a cam swap and thinking of going HSR 383 later on..but that wont be til later and car is not really daily driven i just take it to school when i feel like it or just go cruise and mess around the streets(local track closed so the streets is where the action has been happening) so wat do u say? and i do plan and running et streets or drags with some drag lites and bigger/wider tires just depends how big of a tire i can put on my 3rd gen..so wat do u think??
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
I have a stock 350 with all the mods you can do without going into the motor, chip, throttle body, runners, ported plenum, bypass, etc. I have a stock 3.27 borg warner 9 bolt posi. I built a 9bolt 3.70 gear that makes great low end torque and power though the power band in the 1/4 mi, and only lost 250rpm difference at 70 mph. The 3.70 will bite with better traction and less wheel spin on take off, I lift the front end more and spin the tires less and don't lose that much less on highway driving. Over all i like the 3.70 gear better. The 3.70 gear is similar to the 3.73 10 bolt in rpm range, so i think you will be better suited with the 3.73 with a stock motor than the 4.10. However if you start hitting the 380-425 hp the 4.10 will then start preforming better in the 1/4 mi. This is only my perspective and my opinion on my experience? It may be mechanically easier to change tire size than gear ratio, but what ever you do you will have to change the speedometer gear ratio accordingly to have an accurate reading.
Car: 1985 IROC-Z
Engine: 355
I don't recommend street racing but you will do what you will do. If you are on the street higher gear ratios will perform the best with the right tire setup. With 4.10s Your 0-60 times will increase and stop light to stoplight you will be much quicker without any modifications at all. So I would go with the 4.10. Also when you start upgrading you motor you will have a better platform for the strip.
Your speedo will be inaccurate, you will get poor gas mileage and your car will be winding at highway speeds.
But as you said its not a DD so these things really do not matter.
Car: 87 IROC L98
When I had 3.27 gears many, many years ago, I had enough HP to push the car to 12.0 @ 117 mph. The gearing wasn't correct for the combination but I still made them work.
Car: 87 Iroc Camaro
Engine: 5.0
i have a mostly stock 305 tpi automatic iroc with the exceptions of headers exuast. i have 2:73s i think and im running 15.5s in the 1/4 now. its mostly a daily driver. i also am thinking about putting in 3.73s, how much in the quarter would i pick up if i went with a 3.73?
I changed the speedo gear, i have the correct one for 4.10s, modified a th350 gear to work with my vss, as accurate as it can be. can anyon e tell me what there t-5/v8 combo revs are @ 60 with 3.42 and/or 3.73?
Since TPI makes the bulk of it's power at lower RPM it doesn't make a lot of sense to put steeper gears in the back since that will raise the RPM for a given speed. The longer you keep the engine in it's happy place, the faster the car will go (to an extent). That's why 3.23 and 3.42 gears work so well in these cars. GM had 3.73 and 3.70 gears, that they used with the higher winding carbed cars, but for TPI it's borderline too much gear.
Car: 1985 IROC-Z
Engine: 355
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Very little if nothing in the quarter mile. The 305 tpi's dont pack enough up top to use the higher ratio to its full potential. You might benefit from a 3.27. But with a 3.73 or a 4.10 you will really loose out up top were it counts for your motor. If you do get a 3.73 or 4.10 expect to swap out to a bigger motor or heavy modification on the 305 to reach full potential with these gears.
when I switched to a T5 and 4.10 gears, my ET stayed at 15.2 but my mph increased to 93mph.
4.10's were fun but too much for highway driving and since my car is my daily and I use the highways often I was burning up gas like it was leaking out.
Car: 1985 IROC-Z
Engine: 355
Sounds like when you changed your trans this gave you speed on your top end. Switching from a 3.73-4.10 wont give you more speed unlesss... You have a taller tire.
And wow had no idea that going from a 3.23 to a 3.73 would have that much of an impact on E/T with stock platform. Ive always heard that a stock motor will not perform better with a higher gear ratio in the quarter only 0-60 and 60'. I also have never driven different gears on the same platform. Always have swapped gearing when there was more power available.
Car: 1991 camaro
Transmission: 700rr4
I have a 1991 camaro rs with a 305 engine all stock and was wondering if 4.10 gears would make the car go a lil faster at the start of a race?? and if i ever put the 4.10 gears wat do i need to change ?? Or is it just the gears?
Car: 1987 iroc
What transmission do you have? An Auto or a stick? What gears do you have now? Either way, 4.10 gears are way to high for a stock 305.
Car: 1991 camaro
[QUOTE=red rock;6253364]What transmission do you have? An Auto or a stick? What gears do you have now? Either way, 4.10 gears are way to high for a stock 305.[/QUOTE
i got the 700 trani and its auto idk wat gears it has but they are the stock ones i think its 3 somthing and by any chance do u know if i put the 4.10s u think its gonna go fazter at head start?
Car: 1987 iroc
First gear in a 700r4 is 3.06, you combine that with a 4.10 rear gear and you will be shifting immediately to second and third. With a stock 305, you may get a jump up to 50 feet, but your engine will run out of power (to high of rpm). You will throw the whole power band off for the engine you have. 4.10's are for huge power engines. You would benefit more from from a little higher stall converter then you would for gears. According to TGO, you have very low power. https://www.thirdgen.org/1991-chevy-camaro/
Car: 1991 camaro
oh alright appreciate it bro
Car: 89 Firebird
Engine: 355 TBI
I have 3.73s and really they are too steep for my 305 TBI auto car. I plan to change to 3.23s or 3.42s next time I get into the rear end again.S10 t.c.. Really was a big help to mine also, id say it gave it 2200-2400 stall.
Car: 1984 Trans Am L69
I have had 3.42 and 3.73 with both the .62 and .73 5th gear T5. My preference is .63 5th and 3.73 but I also drive 20 minutes on the expressway every day going to work. .73 with 3.73 gave great 5th gear acceleration but I like cruising at 500rpm less.
Car: 1987 iroc
A stock LO3 with 170hp and a 2.73 gear is where VictorMonsivais is at. There is going to be a lot of money poured into making any gains in performance. I would start with building more HP first, depending on whether to keep the 305 or go bigger. Or just stay stock and enjoy the car.
Car: 89 Firebird
Engine: 355 TBI
Adding some gear and TC is the best seat of pants you can give an Lo3. Mine is way more fun. Doesn't feel as slow as it really is. I also have a well built tranny that shifts snappy. huge upgrade from 2.73ss and sloppy tranny.
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Need to post more info, the 383 can be a low rpm or a high rpm runner, where is the power made in the motor?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
MY rule of thumb when ALL other things are equal:
700R4 = 3.42
T5 = 3.73
T56 = 4.11
Driving a 700R4 with anything over 3.42(5) is too quick a gear for any highway driving -----> IMO.
700R4 = 3.42
T5 = 3.73
T56 = 4.11
Car: 1984 z28
Engine: 355
Sure; you can get on the highway,...... but at 2800RPM @ 75MPH your not doing any "highway driving". What's a taller tire get you,... drop a couple hundred RPM maybe ?? Heck; on a typical highway drive I don't even drop my T56 4.11 into 6th until AT LEAST 80mph.
Car: 1984 z28
Engine: 355
You're not driving that fast where you live or where I live on the highway, speed limit is 65 in which like I said is a fine crusing speed/rpm for a 700R4 and 4.11 gears
84 z28
If you're ever on the highway & see this:
,............. Just get out of the way.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
