2001 Z06 6-Speed MN12 with 350 tpi
Old Oct 5, 2010 | 12:51 AM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
will a 2001 Z06 6-Speed MN12 work with my 350 in my third gen. anyone done it? what will i need. do they make a bellhousing for it. and would there be an advatage or disadvantage over the t56. i can get one with 5000 miles for 700 bucks. please help
Old Oct 5, 2010 | 01:09 AM
87350IROC's Avatar
Car: 87' IROC
Re: 2001 Z06 6-Speed MN12 with 350 tpi
C5's have a transaxle which means the trans sits in the rear of the car. I'm sure you could make it work, but it would not be a simple swap.
Old Oct 5, 2010 | 01:46 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Won't work. As said, the C5 trans is mounted to the differential.
Old Oct 5, 2010 | 12:29 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
http://www.eecis.udel.edu/~davis/z28..._Fbody_T56.pdf
It will still be a LS1 version with a long input shaft, but you can use a Muncie-SFI/T5/saginaw bellhousing or quicktime conversion bellhousing to fit it to a SBC. The GTO-clone would be sufficient for a TPI 350 and could be built to handle from 500-700hp easily. The SSR clone could be built if you expected to see from 700-1000hp.
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
