t56 engagement issues
Old Oct 6, 2010 | 02:10 PM
mikesz1984's Avatar
Car: 1984 z28
I have researched on line here and i am having a different problem with my t56 clutch engaging. (i think) When i depress my pedal all the way, i go to shift into gear and the car will lurch forward, and getting it into revearse is impossible. I have though of lengthening the master push rod, but I dont want to damage anything. Is this the best way to fix this issue. This is the second set of hydraulics that has done this to me with. The first set came with the transmission, and the second set I just bought last week. I dont know if it makes any difference, but I used a set of v6 pedals on my car when I did the swap.
Old Oct 7, 2010 | 12:00 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: t56 engagement issues
the v6 slave might not be big enought to push the slave rod or have enough throw in the slave i used 3rd gen pedals or use a set of 4th gen
Old Oct 7, 2010 | 04:21 PM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
also do you know about the reverse lockout solenoid
Old Oct 8, 2010 | 08:11 AM
mikesz1984's Avatar
Car: 1984 z28
the reverse lockout has been deleted on my transmission, i did rebleed the new hydraulics last night, but that didnt work. I am begining to suspect that the 1995 v6 pedals i have just arent quite right for this set up. i will look around and see if i can pick up a set of actual t56 pedals for my car.
Old Oct 8, 2010 | 08:25 AM
tom86iroc's Avatar
Car: 1986 iroc
matt i didnt wire the sol. in i just use a little nudge to get it into reverse
Old Oct 8, 2010 | 11:12 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Try to take out your slave and push it in by hand then have some one step on the clutch pedal, see how much movement your getting, should be around 3/4 to 1" travel on the slave rod. If your getting that then sounds like there is a problem with your clutch or could be a pilot bearing problem.
777Shock777
Oct 29, 2015 04:30 PM
Papaginos
Sep 27, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
