where to check lube level in 88 t5?
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
i have an 88 camaro with 5-speed and it whines a little.
i hate to be so dense,but where do i check the fluid level?
is there a dip stick under hood,or gotta go under car?
also,my vin says car came with automatic.can this be wrong?
thanks,
jd
thanks,
jd
Re: where to check lube level in 88 t5?
The VIN won't tell you if a car is an auto or manual transmission.
On the passengers side of the transmission there will be two plugs with square heads. The bottom is a drain, the top is the fill plug. The fluid should be filled to the bottom of the plug.
thanks drew,
jd
jd
Car: 87' Firebird Formula
