3.23 vs. 3.27 or 2.72
Old Oct 10, 2010 | 10:02 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I just got an 82 trans am with rear disk and am told probly has 3.23 posi in it.which of these rear ends would be best to have in my 89 iroc with 350tpi.and whats the pro's and cons between limited slip and posi
Old Oct 10, 2010 | 11:09 PM
Drew's Avatar
Re: 3.23 vs. 3.27 or 2.72
There isn't enough difference between 3.27 and 3.23 gears to worry about. Posi and Limited Slip are different terms for the same thing. 3.2x gears will give better acceleration from a stop, but you'll lose top end and potentially fuel economy.
I wouldn't swap a 10 bolt from a 82 Trans Am into anything newer, even if it had better gears. Early disc brakes suck, and it'd have 26 spline axles. Your 89 probably has a 9 bolt, which some would consider a much better rear to start with.
Old Oct 11, 2010 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
And if the 82 has a limited slip, it's probably the dreaded Gov-Lock. All in all not a rear, I'd chose.
JamesC
Old Oct 11, 2010 | 10:43 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
THANKS guys,I'll leave it in the 82 and keep my 2.73.I probly wont be doing much racing with it anyhow.
Old Oct 12, 2010 | 04:35 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
JamesC
Gov-locks were only put in trucks from the factory
Old Oct 12, 2010 | 06:02 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
save up and get a good aftermarket rear end. You won't regret it. I put enough money into one of my ten bolts that by the time i got it running correctly I could have bought a complete nine inch.
Old Oct 13, 2010 | 06:16 AM
JamesC's Avatar
My 82-85 F-Body Parts and Illustration Cat. shows it. A search will provide several pages of info on the "Gov lock."
JamesC
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
