Th350 wont shift
Old Oct 12, 2010 | 04:13 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Th350 wont shift
I have a 1992 firebird with a 79 350 and a th350 when i first got the motor in i backed it out of the garage then pulled it back in well today i got mostly everything buttoned up but now it wont shift at all i put it in all gearsand it doesnt move at all. What could be wrong?
Old Oct 12, 2010 | 05:38 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: Th350 wont shift
it has park and nuetral but i too the cooler lines off and its not pumping oil. does the pump just go out like that or wat?
Old Oct 12, 2010 | 05:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It has fluid?
Old Oct 12, 2010 | 05:47 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
yup it looks clean and i checked it in neutral and its full on the stick but its not pumping so i dont understand
Old Oct 12, 2010 | 08:28 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If the pump isn't pumping, chances are the torque converter isn't installed properly to turn the pump.
I can't see you using a wrong converter. Turbo spline input shafts are 30 spline. 700R4 converters have 27 or 30 spline input shafts (depends on the year). There's no way to install a 27 spline converter on a 30 spline input shaft but if you went the other way, the splines wouldn't engage.
Old Oct 12, 2010 | 08:43 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
i bought the car with the trans and converter already with it and he said everything worked fine so im pre sure its right converter but idk if the trans is what he says
Old Oct 12, 2010 | 09:46 PM
How many ft-lbs did you torque the converter-to-flexplate bolts to?
Old Oct 12, 2010 | 10:12 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
i dont even remeber but they arent completly torqued now cuz i took them out to check the converter
Old Oct 12, 2010 | 11:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
With the bolts out of the converter can you freely spin the converter? Can you slide the converter back into the tranny about 1/8"?
Old Oct 13, 2010 | 06:40 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
yes and im not sure i think it might be a little more than a 1/8th but before when i bolted together i dont think u could turn it freely when it was bolted up
Old Oct 13, 2010 | 07:22 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Flexplate on the right way? The tabs that the converter bolts onto should be raised towards the converter. Pulling the converter out too much may disengage the pump.
Old Oct 13, 2010 | 08:26 AM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
yup raised tabs towards converter. Could something in the converter be stuck from setting? because idk how long it was setting and it was supposedly rebuilt a couple years ago. and has around a 2400 stall converter. Do you think and filter change with some addative would help?
Old Oct 14, 2010 | 12:09 AM
AlkyIROC's Avatar
Car: 87 IROC L98
You could at least pull the pan off and have a look inside. See if any hard parts are in the pan. See if the filter fell off. See if linkage fell off.
Old Oct 14, 2010 | 08:28 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
i didnt realize how much crankwalk i have which is very bad with the crank all the way forward and converter all the way back theres 3/8 to 1/2inch gap
Old Oct 16, 2010 | 05:41 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
put spacers in just so i could see if the trans was working and now it freewheels but still not pumping fluid. I drained a bit over a gallon of fluid out of it and it all looks clean and the pan have some dirt in it not a whole lot. So should i change the filter? or is it pretty much junk?
Old Jul 24, 2012 | 10:59 PM
Not'Jur Average's Avatar
waz there ever a solution to this?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
89newfun
Sep 16, 2015 09:28 AM
