Info putting a posi in?
Old Oct 17, 2010 | 12:09 AM
Cody_D's Avatar
Car: 1998 Camaro, The Silver Bullet
Engine: 383 stroker, EB intake and carb
Transmission: Stock 84' T-5
Axle/Gears: Stock as of now, open diff
Just need some helpful info on dropping my rear-end out and buying a posi unit and making it a bit stronger or just making improvements once i get it.
I have a freshly rebuilt 383 stroker, lightened crank, edelbrock performer rpm intake, edelbrock 1405 carb, hooker super comp headers, T-5 tranny fom a 84 w/a 305.
My car is not goin to see any track time just a enthusistic street driving, so any help in trying to do this rear-end would be greatly aappreciated, because i don't know much about rear ends, jst motors.
Old Oct 17, 2010 | 12:37 AM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Re: Info putting a posi in?
I would worry more about the T-5. T-5's aren't that strong and an 84 is even weaker than the newer ones.
Old Oct 17, 2010 | 11:43 AM
Cody_D's Avatar
Ya that's what i hear, but it should stand up to mostly just driving around, no 5grand clutch poppin.
Just want to build posi that i wont blow away in a few days of driving around with that amount of power, unless you guys think that a plain old stock posi-unit would work just fine
I just dont want to spend money on one, then blow it up just cause I was careless and didn't put in some quality parts that could be quite worn already.
Any one know what the common items are to fail on these units?
Cheapest place for new-oem or better than stock parts?
Old Oct 17, 2010 | 01:26 PM
big gear head's Avatar
Are you going to stay with the gears that you have now? If you are then you need to know what ratio they are. I recommend the Eaton Posi if you have 3.23 to 4.10 gears. Here is how to install it. http://www.nastyz28.com/forum/showthread.php?t=19773
Old Oct 17, 2010 | 04:00 PM
Cody_D's Avatar
I am prolly goin to get a whole different differential than what is in the car now. This weekend but i am nt sure what to do after i get it. Just put it in or tear it apart and make it stronger before I put it in.
Unless i can use the the open diff i have now and make it a posi, i am nt sure, any help?
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
