Pulling a 700R4 without the TC=EPIC FAIL!
Old Oct 19, 2010 | 07:41 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
Just thought i'd share my unfortunate-ness of the night. Figured I could pull my auto transmission without the torque converter, but i was very wrong. I've twisted, turned, raised and lowered the transmission and looks like the bellhousing keeps getting hung up on the firewall. So this sucks.
Old Oct 19, 2010 | 07:48 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Pulling a 700R4 without the TC=EPIC FAIL!
you need to get a ratchet strap and pull the motor forward some to allow clearence, it will come out you just have to get the angle right
when you pull the trans off the motor it tends to lean backwards(especially if the mounts are worn) thus making it harder to get the tranny over the converter
Old Oct 19, 2010 | 08:46 PM
I'm just gonna pull the TC. I've done this many many times and it's always been a breeze for me, just thought this would be easier but nope. No biggie, just won't do it again!
Old Oct 20, 2010 | 05:41 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Well, at least you won't lose any more sleep over whether or not it can be done?
Old Oct 20, 2010 | 10:04 AM
squeeezer's Avatar
Car: 5 cars
now your seals are f@#$ed up
Old Oct 20, 2010 | 11:00 AM
Got it pulled guys. Took all of 20 minutes to unbolt it from the flexplate, unhook the lines and get it on the ground. The seals were primarily why I was pulling it. So no worries there.
Old Oct 20, 2010 | 02:37 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
What exactly was or would have been the benefit of not unbolting the TC? Because i'm curious to know how you thought you were going to get the trans back in without installing the TC first completely into the pump. Your lucky that you got into that bind while taking it out instead of putting back in. Because if you started the car up with the TC not engaged into the trans pump you would have had some REAL problems.
Papaginos
Sep 27, 2015 03:29 PM
86IROC112
Aug 31, 2015 07:00 AM
JHX
Aug 29, 2015 02:30 PM
GouldyGTR
Aug 21, 2015 10:43 PM
spaigo
Aug 21, 2015 07:46 PM
