700R4 Front pump seal (I've searched)
Old Oct 20, 2010 | 08:46 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
So my front pump seal, that goes around the shaft, will leak a pretty good bit if sat for about 2 days or so. If I drive it everyday then it's alright, also it my tranny would slip sometimes in first and sometimes in third when I step on it. I never did put the correct amount of fluid in when I had my engine rebuilt and what not, but haven't driven it but up the street. And fluid is definitely getting to where it needs to go. My question is, why is it that if the front seal is to be replaced, that deems the pump is bad? I don't get it. Why not just replace the front seal and carry on?
Old Oct 20, 2010 | 08:53 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
Re: 700R4 Front pump seal (I've searched)
If you have slip in the trans, I'd stop driving it anywhere...put it on a level surface & top it off. If you still have slip, you likely have some burnt steel and fiber plates and will need to pull the forward clutch....not so easy to do. If it does not slip, I would replace the front seal. be sure to check the shaft for a bur also.
Old Oct 20, 2010 | 09:02 PM
Thanks for the swift response. I definitely know it's a lack of fluid cause when it was close to full, it was great. Now I have the tranny on the ground and I'm ready to do the front seal. But was searching and saw people were saying you need a rebuild or new tranny if just the front seal is leaking. Also a "bur" on the shaft, what do you mean exactly?
Old Oct 20, 2010 | 09:06 PM
Sandslot's Avatar
Engine: LB9
Sometimes if the torque converter is installed "roughly", you can develop a bur or nick on the shaft...which depending on where it is can cut the seal. this is especially true if the converter had a nick on it. Check both surfaces that run on the seal. Also, when reinstalling the converter, put some light grease on the mating surfaces
Old Oct 20, 2010 | 09:21 PM
Awesome. Definitely aren't any nicks or grooves on the torque converter itself but haven't inspected the shaft. Will check the shaft tomorrow before I buy the $4 seal. Any tips or articles on replacing this? Never done one before and normally I'm pretty good at diving into things, but I have no experience in this area. Thanks a lot!
Old Oct 20, 2010 | 09:25 PM
Sandslot's Avatar
Engine: LB9
Just take your time. Start when you have all kinds of time...work your way around the seal with a lightweight hammer. Its got a nice flange...but you just need to be patient. Don't let the start of the seal frustrate you...you'll bend/kink it & then you'll need another.
Old Oct 26, 2010 | 10:14 AM
I'll probably get two then. Heck they are only $4 a piece.
Old Nov 5, 2010 | 08:21 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If the bushing in the pump (behind the front seal) is worn, a new seal won't last long. Be sure to inspect it carefully while the seal is out.
Old Nov 6, 2010 | 02:23 PM
Pro Built Automatics's Avatar
Front seals do not leak from sitting. They are a pressure type of seal and will leak when running, and stop leaking when the motor is turned off. I have never seen a front seal leak when sitting in 33+ years of doing this, and I have talked to other builders about this with the same results. Top hat seals at the TV cable or dipstick tube are the most common leaks when sitting. Front pump bolt seals rarely leak.
Old Nov 6, 2010 | 07:49 PM
This would make sense. Unfortunately I little to no experience with transmissions so it was just a first thought. I also think it may be time for a filter/pan gasket change. Also I discovered both of my trans lines to have very small leaks. I will be tackling these tomorrow and hope to have it resolved. Thanks for all the help!
Old Nov 8, 2010 | 06:07 PM
Turns out it was my TV cable seal!!
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Exxon Limited
Aug 9, 2015 08:13 PM
