losing axle fluid?
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
losing axle fluid?
I had two of my heat sheilds under my car today, but it was really windy out so i went outside to i could move them to my shed but when i pulled them out one of them had a axle or differential fluid onit, how am i loosing this fluid? i havent messed with the axle or differential at all, the most iv done NEAR it was replace my rear sway bar links but even that its far from it, this is the first time iv noticed it and iv had those heatsheilds under the car for awhile now so im lost, any help here? is my diff cover lose?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: losing axle fluid?
please wait at least 24hours before bumping a thread, give people a chance to read it. Not everybody is online all day long.
where is it leaking? could be the pinion seal
Car: 87 GTA
My cover bolts keep loosening up very slowly. I keep tightening them up, but like 2 or 3 times a year, I have to tighten them back up.
I know I should pull it off, clean the threads, dab some Loc-Tite on the bolts, but I just never have. I do add fluid through the rubber plug though, so I'm in no danger of it going dry.
Engine: L31 350
i didnt see where it was leaking at, like i said i pulled my heat sheild out and it had it on it, it has to be either right infront of the differental or from the differental
Car: 86 Trans Am
If its the pinion seal, its easy enough to change, just have to make sure the pinion nut is installed back to the exact place it was before so you dont affect the pinion bearing preloads.
Its probably the cover
Engine: L31 350
ok thank you, can i get the gasket and oil from autozone?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
any obvious wet areas shoud be an indication . if the area is just too greasy/oil soaked , clean it . you may be lucky enough to find a carwash that sprays the under side of car in your area . if you can't do any of the above , blow flour , baby powder , talc , etc. around suspect areas . drive around and area should show up . good luck .
Engine: L31 350
i checked autozones website but i didnt find the gasket, all i found was the cover which came with the gasket for like $12, but im still not finding the fluid.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You should be able to purchase a gasket at any of the auto supply stores.
JamesC
JamesC
Engine: L31 350
going to get the gasket and fluid from orilleys when i get my exhaust pipe from there sometime this weekend.
HoosierinWA
Oct 7, 2015 10:15 AM
