which gears to get
Old Oct 28, 2010 | 12:09 AM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
which gears to get
which gears to get for my 305tbi with 700r4 with basic upgrades no real big motor mods . i was thinking 3.23 which would liven it up a bit or should i go with 3.73? need some advice since this is dd and sont wanna go overboard with it
Old Oct 28, 2010 | 06:34 AM
Re: which gears to get
3.23 is MUCH better than what you have now. 3.73 is too much for a TBI motor with stock heads; you end up with basically the "tractor motor" thing,the problem where it leaves HARD but can't even keep up with traffic let alone pass anybody on the freeway, the fun is all over with before you hit 5 mph. 3.42 is about as far as you want to go.
Old Oct 28, 2010 | 08:56 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I totally agree that 3.42 is the way to go.I went from 2.73 to 3.42 and upgraded to 28 spline axles and Eaton posi. Totally different feel. Pulls hard but is decent on the free way with the 700r4 OD. If you don't have a posi. I strongly recommend a Eaton posi. and LPW support cover while your in there.
Old Oct 28, 2010 | 10:21 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
I have the same car same engine and transmission I installed and eaton posi and 3.73 gears and I have noticed a good difference. And if you plan on doing an engine swap or upgrading your engine I would go with the 3.73 gears Oh and Im gona send you a PM .
Old Oct 28, 2010 | 10:59 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
ok so what all will i need to but the shop i tlked to said tht they would go ahead and replace the bearings so i gotta buy them. also where can i get a good set of gears? summit or jegs
Old Oct 29, 2010 | 01:17 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
either place is fine.
I'd recommend that you skip building your own and pick up a gently used 4th gen rear end with 3.23s or 3.42s and disk brakes. Will be cheaper, just as strong, and opens the door to 4th gen wheels.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
