hard shifting 700r4
Old Oct 31, 2010 | 04:15 PM
Camarokid08731's Avatar
hard shifting 700r4
just picked up a 88 camaro with a tbi 350 the kick down cable is not hooked up the clip broke waiting on a new cable to come in but my symtoms are when putting it into drive it violently bangs into drive, then when driving it takes forever to go into second then just bangs in. havent really driven it just wondering what this might be and if its just because the kickdown cable is not connected.
Old Oct 31, 2010 | 10:35 PM
Pro Built Automatics's Avatar
Re: hard shifting 700r4
It is now in the factory "limp mode". Replace the TV cable asap, and do not drive it, unless necessary. Make sure that the new TV cable is tight at WOT.
Old Nov 1, 2010 | 10:04 AM
Ok so all this is due to the tv cable and will be solve when installed and adjusted?
Old Nov 1, 2010 | 10:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes
The transmission "sees" that the TV cable is fully retracted, so it maxes the line pressure to cause late, hard shifts as a last resort to avoid more damaging soft, early shifts. The car isn't driveable in this condition, except in an emergency.
Hotrodboba400
Dec 10, 2019 07:07 PM
Vojtush31
Oct 11, 2015 01:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Randomtask2
Sep 7, 2015 05:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
