9 bolt making popping noise since r&r
Old Nov 3, 2010 | 11:07 PM
Ericsxtnirocz's Avatar
I was trying c if anybody could help me out.I just recently replaced my rear end cause it was blown with a used one.it's the Borg Warner nine bolt.when I make right turns the car vibrates from the rear end and when i reverse and turn to Parnell it pops an shakes
Old Nov 3, 2010 | 11:32 PM
big gear head's Avatar
Re: 9 bolt making popping noise since r&r
If the oil hasn't been changed in a while then change it and use a bottle of the GM oil additive. If the oil is fresh then put in a bottle of the GM oil additive.
Old Nov 4, 2010 | 12:31 AM
I put the additive from kragen in there.it's called sta lube or something.it sais it's for limited slip and posi.u think it makes a difference from the oem brand.and is 80 90 gear oil ok.I mean that's what I used when I put the rear end in te car? O yeah I found a couple teeth,like 3 when I changed the oil.I was thinking I might b one of the taperd bearings on the axle shaft I jus haven't been able to take it out yet
Old Nov 4, 2010 | 12:46 AM
The GM and Ford additives are the only ones that I have seen that actually work. The other stuff usually doesn't work. If you found teeth in the rear end then you have bigger problems.
Old Nov 4, 2010 | 04:05 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
and ive seen where the gm additive wont work n the ford rears and the other way around as well..
Old Nov 9, 2010 | 12:55 PM
So r u saying the rear end will b popping and vibrating if I don't use the Gm name brand additive.the kragen additive doesn't work. And Is there is a possibility that the taperd bearing inside on the axle shaft right by the wheel could make it do that
Old Nov 9, 2010 | 03:38 PM
The bearing could do that, but almost every time someone asks this question it is because of the oil additive. Use the GM or Ford additive and your problem will most likely go away after a day or two.
Old Nov 11, 2010 | 10:02 AM
I'm not sure if I bent that long bar connected to it because when I put the rear end back on the car it was hell lining up that bar to screw those bolts in behind the wheel well,that skinny bar that runs along the rear end.u think I should change that bar.I already changed the shaft and the wheel bearing and the car turns hella hard to the left now.it didn't do that before,the rear end kinda moves like it shifts or sways and then pops
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
BrianI
Aug 9, 2015 11:52 AM
