are the eaton gov locs on ebay any good ?
Old Nov 8, 2010 | 11:59 AM
ray jr's Avatar
im building a tpi motor for my iroc and also doing the rearend and saw the 28 spline eaton gov loc posi's on ebay for 175.00 some with gears .. are these any good ? or do i have to go to summit to get a eaton posi or auburn pro series carrier ? any other options ??
Old Nov 8, 2010 | 12:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: are the eaton gov locs on ebay any good ?
Originally Posted by ray jr
im building a tpi motor for my iroc and also doing the rearend and saw the 28 spline eaton gov loc posi's on ebay for 175.00 some with gears .. are these any good ? or do i have to go to summit to get a eaton posi or auburn pro series carrier?
Most would say that the Gov Lock isn't worth the effort/money. big gear head advises the Eaton.
JamesC
Old Nov 8, 2010 | 12:47 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
they are commonly called grenade locs, leave them alone....get a modern type eaton, auburn, detroit tru-trac or if you're lucky enough to find an SLP zexel torsen take out like i did.
Old Nov 8, 2010 | 01:04 PM
ray jr's Avatar
thanks guys .. i almost bought one ..
Old Nov 8, 2010 | 01:09 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Yeah, leave them alone. They are fine in truck or non-performance applications. When you put some power into them the ratcheting mechanisim strips or breaks. I also discovered that when driven into a corner hard, it will open up and one wheel peel. Right about the time the vehicle straitens up it locks and the rear becomes loose fast!
Old Nov 8, 2010 | 05:34 PM
big gear head's Avatar
The Gov Lock is fine in a stock truck. They don't hold up too well in a performance car. The eaton Posi is the best choice for a street/strip car. The Torsen would probably be better for auto cross or road racing.
Old Nov 12, 2010 | 03:37 PM
In 2002, SLP did "some special edition" packages with Trans Ams/Camaros and part of that package was zexel torsen posi upgrade, along with forged 28 spline axles, 4.10 gears and a stud girdle cover for the rear. The rest of the package included suspension tweaks and engine mods. I remember in 2004, i was on ebay and saw one those camaros wrecked and was being parted out, i took the torsen posi and the aluminum driveshaft from it.....both are still taking wretched (nitrous soon to be twin turbo) abuse in my car right now 6yrs later!
hectre13
Dec 11, 2023 08:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
the_nikfive
Aug 11, 2015 02:46 AM
novaderrik
Aug 10, 2015 12:44 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
