Clutch Pedal
Old Nov 12, 2010 | 05:34 AM
PS116:16's Avatar
Car: 89 Camaro RS, 97 Caddy Deville
Engine: 350 TPI, Swap out
Transmission: Automatic 700R4
Axle/Gears: posi trac rear
Clutch Pedal
Hey guys, i know that this site is for 3rd gens, but i have a 1998 Camaro six cyl. manual tranny. which is actually my daughters car. She called me stateing that the pedal goes all the way to the floor and will not shift. My son went yesterday for me to correct the problem which i thought the clutch line (hydrolic) needed to be bled. once this was done, the tranny would shift, but the clutch pedal would only come back up halfway. then we re-bled, and we started to drill mod the clutch line, which ended not being done. he drove it around said clutch was fine, just pedal. does anyone know how to correct clutch pedal so that it will come all the way back to normal position? or is there something else i need to be looking at? thank you
Old Nov 12, 2010 | 06:41 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Clutch Pedal
Is it loosing fluid? Just a guess but it sounds like the slave cylinder might be loosing it's seal?
Might jump over to http://www.camaroz28.com and go to the appropriate model section for your 98 6 cyl, for some advice.
Good luck
Old Nov 12, 2010 | 02:43 PM
PS116:16's Avatar
Re: Clutch Pedal
ok thank you
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
