Flywheel starting problem 1992 camaro
Old Nov 16, 2010 | 02:05 PM
camaro55555's Avatar
I am looking to buy a 1992 camaro with 122,000 miles, 5 speed transmission, and a v6. He is selling it for $1000 but he says it wont start because somting is wrong with the flywheel. How hard is it to replace the flywheel and how much will it cost me.
Old Nov 16, 2010 | 03:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Flywheel starting problem 1992 camaro
make sure it does have something to do with the flywheel. that sounds like a BS excuse to me, most likely has other problems.
the flywheel is bolted to the back of the engine, to replace it you have to remove the transmission and clutch assembly fromt he car. Not a terribly hard or uncommon thing to do, its all dont from the bottom of the car, so a lift would be ideal, but can also be done with floor jacks and jackstands. Or take it to a shop. Might as well figure on a new clutch and pressure plate while your in there.
but like i said, i dont see what could be wrong with the flywheel to keep the car from starting. Unless the teeth are broken off.
does the car crank at all? It all seems a little sketchy to me.
Old Nov 16, 2010 | 06:09 PM
Not sure how this is an issue?
The flywheel and the starter only fit a 6-cyl, as does the T-5 and its BH for that matter; so all that will of course be going in the garbage anyway. Why worry about it?
Old Nov 16, 2010 | 06:16 PM
Here is the description:
1992 RS Camaro 5spd v6 3.1 122xxx miles., something wrong with the flywheel. I have replaced fuel injectors, spark plugs, spark plugs wires, ignition coil, distributor, distributor cap, rotor, fuel filter, oil filter, TPS, and MAP sensor. Don't have time or money to work on it anymore. Selling $1000 OBO.
Old Nov 16, 2010 | 06:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i would ask about the flywheel, what exactly doesnt the car do that makes the guy think there is something wrong with the flywheel. with all the other work, it seems like they are chasing ghosts and cant get the car to start.
Old Nov 16, 2010 | 07:02 PM
At firsthe thought it was the starter but then he took it to a mechanic and the starter was fine and the mechanic told him it was the flywheel. I will ask him what the mechanic exactly said.
Old Nov 17, 2010 | 06:20 AM
Ok I talked to him and he said that the flywheel has a bent or broken tooth on it.
Old Nov 17, 2010 | 07:34 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
It should run and drive with a busted flywheel / flexplate, mine did. Then I learned they only go on 1 way LOL. The bolt circle was ripped apart from the rest of the flexplate so it really wasn't connected, but it still drove some how. It made a good bit of noise, like a loose exhaust component would. Pulled the engine and tranny out thinking there was something wrong with the engine, separated the tranny from the block and the flexplate fell off!! The only other problem, other than the noise, was the starter wouldn't grab some times. After that I felt very lucky to be alive, I drove it like that for at least a week, alot of time for something terrible to happen. Ask whats wrong with it and why he thinks its the flywheel, get under the car and try to move it around. Try to start it for a second just to see if the guys trying to BS you, but no further than that.
Vintageracer
Jan 10, 2020 05:33 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
