Which flywheel?
Old 11-20-2010, 06:57 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Which flywheel?
I need a new flywheel. Have no clue which ones are good and cheap. Here's the quick info.
-500hp 383 internal balanced 1 piece rear main seal
-Using the starter that came out of the 96 tahoe 5.7 vortec
-bolting a 700r4 non lockup 3k stall
Not sure if the truck had a 168 tooth or 153. I didnt want to buy a new starter. any help will be appreciated
Old 11-21-2010, 07:04 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: Which flywheel?
ment flexplate ot flywheel
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
Vincent135
09-28-2015 10:50 PM
mfp189
09-27-2015 09:25 AM
monte87cortez
09-26-2015 08:10 PM
el_muerte
09-16-2015 12:01 AM
Quick Reply: Which flywheel?
