clutch question.. immediate attention.may need to return
Old Nov 25, 2010 | 01:16 AM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
i bought a clutch kit from rockauto.com.. and i was fiddling with it n i noticed the clutch wasnt the exact size of the pressure plate it was slightly bigger.is this a problem? and do these pics look ok?
Uploaded with ImageShack.us
Old Nov 25, 2010 | 01:35 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: clutch question.. immediate attention.may need to return
the clutch should not be covering the pressure plate to flywheel mounting bolts, I think you have an issue on your hand.
I can pull a stock clutch off my shelf on friday and take measurements for you if you like.
Old Nov 25, 2010 | 03:17 AM
Axle/Gears: 3.47
please do. it would be greatly appreciated
Old Nov 25, 2010 | 03:22 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Definitely not a correctly matched set. Send it back.
On a lighter note, is that the disc needed to help the numerous "how do I use a V6 T5 behind a V8" thread starters?
Old Nov 25, 2010 | 08:52 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
when I go into work tomorrow I will do that.
Old Nov 25, 2010 | 12:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
can you post your clutch and pressure plate diameters?
Old Nov 25, 2010 | 05:40 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Looks like you got an 11" clutch disk with a 10.5" pressure plate. You need the matching 10.5" clutch disk.
Old Nov 26, 2010 | 11:17 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
hope this helps, typical installed set, what it should look like, and 10.5" length.
Attached Thumbnails clutch question.. immediate attention.may need to return-clutch.jpg
Old Dec 10, 2010 | 03:30 PM
HotRodV6's Avatar
Car: 93 S10 RCSB
Engine: Corvette LT1
Transmission: 93 M29 T56
Axle/Gears: 8 3/4
You def dont have a matched set there.
I have a quick question i hope can be answered, can you run the 14" 168 tooth flywheel and 11" clutch inside the stock third gen T5 bellhousing? Is there enough clearance? Im swapping in a stock TBI 350 into my 93 S10 and want to keep my stock WC T5 using the astro van 11" clutch and a third gen T5 bellhousing.
Thanks for the help, its greatly appreciated.
Old Dec 10, 2010 | 11:24 PM
jmd's Avatar
jmd
No. No.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
