IS my 700r4 locking up? can't tell
Old Nov 30, 2010 | 02:21 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Removed all smog/emissions equipment. Removed CC Quadrajet and installed Holley. Replaced distributor with vacuum advance dizzy, so the computer is basically not doing anything useful any more.
Will these mods prevent the 700r4 from locking up? How can I tell if it's locking up?
Old Nov 30, 2010 | 07:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: IS my 700r4 locking up? can't tell
The computer won't lock it with that configuration.
Old Nov 30, 2010 | 07:42 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
See sticky at top of carb forum for alternate methods of lock up.
Old Dec 1, 2010 | 02:19 AM
oamhmad's Avatar
Car: 84 Trans AM
From my understanding the computer won't lock the transmission when it's in open loop mode and it can't get out of open loop mode because I don't have an o2 sensor signal to it any more. I still have the coolant sensor hooked up to the ECU. Is there a way to fool the computer to think its in closed loop mode so it will lock the transmission? My Haynes manual makes it seem like the ECU will go into closed loop by it self after a certain amount of time, like 3 minutes, regardless of what all the sensors are telling it.
I'm just thinking of a way to do this without having to spend $60 and crawl under the car and make a mess out of dropping the ATF fluid out.
Old Dec 1, 2010 | 09:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There's probably a way, but it'd probably cost you more than $60.
No need to drop the transmission pan if you really don't want to, but then again it's probably time you replaced the fluid and filter anyway.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
HikoriYami
Sep 21, 2015 07:11 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
