Problem with megashifter indicator light
Old Dec 12, 2010 | 04:36 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
I am unsure how to hook up the gear indicator light on my megashifter. I just don't see anything for a light to connect to. I bought the megashifter from guy new in the box, but I've done that before and had things missing. Reading the instructions it almost sounds like all the lighting (bulb and white piece it plugs in to) from the stock plate should be attached to the new B&M plate but I just don't see how. Can anyone straighten me out. I'm sure it is something simple I am missing since doing a search shows I am the only one who has had their but kicked by this. Everything else is going good with the install.
Old Dec 15, 2010 | 03:35 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: Problem with megashifter indicator light
I don't think the kit plugs in. I think I just cut the harness and spliced the wires. The bulb is pretty dim and doesn't really work very well anyway.
Old Dec 15, 2010 | 09:22 AM
chevysquid's Avatar
That would make more sense to me. I'll look for a place to connect the wires. Thnking about it now the window was already installed on the shifter, I probably need to disassemble it a bit and will see where to hook it up.
Old Dec 18, 2010 | 10:02 PM
chevysquid's Avatar
Figured it out. A previous owner had the whole thing assembled but left off the light bracket and I found it in the chilling in the box. Now I just need to hook up the linkage down below and get everything adjusted.
TheJoeY88
Dec 31, 2016 07:30 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
