700r4 shifting problems
Old Dec 22, 2010 | 12:15 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
Transmission: 700r4 w/huges 3000 stall
Axle/Gears: 3.73 posi
i have an 89 rs with a 700r4 3000rpm stall. it decided to start acting up the other day. when in OD it shifts 1 and 2 but as soon as it goes to 3 it free revs until your in the higher rpms when it starts to catch. manualy shifting you can go from 1 to 2 fine but when its in D or OD it doesnt want to go anywhere and free revs till high rpms. fluids good and cables working properly......any ideas/sugestions
thanks
Old Dec 22, 2010 | 04:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 700r4 shifting problems
Hate to be the bearer of bad news, sounds like the 3/4 clutch pack is gone. Which is the most common fail point (worn out) of the 700R4.
RBob.
Old Dec 23, 2010 | 09:40 AM
torque_is_good's Avatar
RBob.
+1 on that
Old Dec 23, 2010 | 09:42 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
RBob.
Yup. That is the typical way that they die of old age.
Old Dec 23, 2010 | 11:32 AM
If you must drive it, then keep it below 35mph or so. You will eventually burn the fluid and begin to cause more damage if you keep driving it.
Old Dec 23, 2010 | 08:49 PM
89_camaro's Avatar
Car: 89 camaro
Engine: 355
thanks to everyone for the help...so im guessing the best fix for the problem would be a complete rebuild?
Old Dec 24, 2010 | 06:45 AM
You asked what would be "the best" fix. LEt's not even consider a street/strip tranny because you don't need that much beef. Yes, a rebuild would be best. If you keep driving it then you will be adding to the cost of the repair.
If you pull the tranny yourself then because you already have problems, you should be able to find a local shop that will rebuild it for around $700 including a rebuilt torque converter. IF you pay a shop to drop the tranny and and re-install, then add $500 - $600 to the price and that's for a stock rebuild.
My tranny shifts fine, but since I'm restoring the car, I have a local guy who will rebuild it for around $425. Again, that's only because the tranny is in working order but I know it will fail in the future (high miles) and since I'm re-doing everything on the car (engine too) then spend a little $$ for peace of mind
good luck as it's probably not what you want to hear but high mile and older cars need to be refreshed.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
