shifter help
Old Dec 26, 2010 | 02:56 AM
bduffey723's Avatar
Car: not a camaro anymore
shifter help
i hate having to push the button in the drop a gear. can i juss take that out or am i screwed with it?
Old Dec 26, 2010 | 04:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: shifter help
If you take the center console cover off, you'll see that pushing the button pushes downwards on a tab that rides in notches - it's spring loaded - remove the spring and it might be free then.
BUT.... Life is going to be REALLY REALLY dangerous without that - you'll end up bumping into reverse at 70mph (or a passenger, or your dog, or that drink, or something falls forward as your stopping. etc.) There's a reason that cars have ALWAYS had some method of preventing and accidental shift change in an automatic.
Old Dec 26, 2010 | 05:00 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
Re: shifter help
well if you wanna make it so you can drop a gear you can probably custom grind the groves the stop it from droping gears so itll still not go into reverse but you can downshift
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
