gear swap
Old Jan 2, 2011 | 02:38 PM
bcmag's Avatar
gear swap
anyone know of any good detailed articles on swapping in3.73 for 2.73 in an 87 iroc w stock posi rear?looking for how to and list of all necessary parts.
Old Jan 2, 2011 | 03:35 PM
Drew's Avatar
Re: gear swap
https://www.thirdgen.org/forums/tran...axle-gear.html
The link is for a 10 bolt and you've probably got a 9 bolt, but the principles are the same.
Old Jan 2, 2011 | 05:23 PM
Stock Car Racer's Avatar
Re: gear swap
[quote=bcmag;4775650]anyone know of any good detailed articles on swapping in3.73 for 2.73 in an 87 iroc w stock posi rear?looking for how to and list of all necessary parts.[/quote
I don't know if I am reading this right.
You want to swap a 3:73 for 2:73 gears?
Or you have 2:73 gears and would like to put 3:73 gears in your differential?
In a 2:73 differential - which is a #1 carrier - you would need a spacer between the ring gear and the posi carrier - not a good idea.
If you had a 3:73 gear set and wanted to go backwards to 2:73 - you would need a different carrier - because the 3:73 is either a #2 or a #3 carrier and they do not interchange.
I have never seen a 9 bolt rear end.
The S 10 pick up, G body - Monte Carlo, Pontiac Grand Prix, Buick all used the 7.5 carrier.
Except the Grand Nationals and Pontiac 2+2 used a 8.5 inch ring gear.
Old Jan 2, 2011 | 05:50 PM
bcmag's Avatar
Re: gear swap
oops going from2.73 to 3.73.sorry
Old Jan 2, 2011 | 08:29 PM
big gear head's Avatar
Re: gear swap
There is a special thick 3.73 gear that is made to fit the 2series differential in the 7.5 10 bolt. This is the only rear end that has these gears available for it. You will also need a good installation kit. Don't buy cheap crap or anything from Summit or Jeg's. They don't have good installation kits.
Old Jan 3, 2011 | 03:56 PM
bcmag's Avatar
Re: gear swap
thanks for the info guys big help!I'll let ya know how i make out
1984HO
Mar 19, 2021 11:59 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
