auto swap
Old Jan 4, 2011 | 06:18 PM
dergafication's Avatar
Car: 89 iroc z
Engine: 5.7 TPI
auto swap
im looking at buying a camaro, around my area most of the good z 28s are all auto's. i've heard its not all that complicated to switch it over.. is this true or what goes into that, help greatly appreciated im looking forward to buying a camaro and getting started. third generation that is.
Old Jan 4, 2011 | 07:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: auto swap
Welcome to TGO.
I think the reason you see most Z28's with auto tranny is because, if they are a 350ci car, that was the only option available. The 5speed (T5) won't hold up well to the power of the 350 motor, and thus GM never offered a 350/5sp option in these cars.
To swap to a 5 speed, you'll need the tranny of course, the crossmember, and the pedal assembly from a 5 speed car. You'll have to cut/drill holes in the firewall for the pedal assembly, etc. There's a ton of threads on here about it - use the feature.
You'll never be able to dog the T5 behind a 350 or anything bigger- it won't handle it. Many folks swap in a T56 6speed from a 1993 - 2002 F-body car - much stronger tranny, but more expensive swap. T-56 can handle alot more motor.
Old Jan 4, 2011 | 07:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
There is a tech article on the topic linked from the thirdgen.org homepage. The Transmission/Drivetrain forum would be a better place to search for info (moving there now).
Old Jan 4, 2011 | 08:12 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: auto swap
I did it a few months back - In hindsight, it really wasn't that bad to do at all. Basic hand tools and some way to cut a hole for the shifter and the clutch master cylinder and you can do it.
https://www.thirdgen.org/forums/tran...y-t5-swap.html
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
LittleFranks
Sep 17, 2015 12:22 PM
gta90
Sep 15, 2015 04:00 PM
