Fresh rebuild, overdrive acts like neutral
Old Jan 16, 2011 | 08:48 PM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
I had a broken foward sprag, causing the transmission to act like neutral in OD.
I recently just finished a full rebuild on it, including all new seals/clutches/stator/shift kit/converter/solenoid/bands/a new 29 element sprag. This has worked, and after almost 200 miles on it, It just "clunked" and went right back to how it was. OD acts like neutral again.
What gives?
Old Jan 16, 2011 | 09:03 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: Fresh rebuild, overdrive acts like neutral
were is reverse is it past the drop on the shifter because if it is you need to adjust the shifter cable at the trans. what may be happening is what is shown on the indicator is back almost one full position. that would literally put neutral in the overdrive spot
Old Jan 16, 2011 | 11:50 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Maybe the forward or overrun piston is cracked
Old Jan 17, 2011 | 04:13 AM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
The shifter cable is adjusted correctly. All the other gears work fine, and it has been driving fine for 200 miles.
We inspected each piece before we put back in, I would think we would've noticed a cracked apply piston. What purpose does this serve in overdrive specifically? Because All of my other gears work just fine.
What are the chances its not a faulty sprag unit? We tested it before we put in and it held well, but who knows.
Old Jan 31, 2011 | 02:28 PM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Solved. Just in case anyone cares, sprag failed again. Took it apart and it was torn to pieces.
Old Feb 1, 2011 | 02:40 AM
Pro Built Automatics's Avatar
When the sprag itself fails, you almost always will have to replace the inner race and sometimes the outer race. The inner race must be perfect shape, very flat and smooth (polished). The outer race must be rough to keep the sprag from turning. If the outer race is in good shape, then use 36-40 grit sandpaper and sand the inside by rolling it across a wooden bench, press down hard and do this about a dozen times. If you look at a new outer race, you will see that is has machined grooves going in the direction of rotation in it. This is to keep the sprag from turning.
Old Feb 1, 2011 | 12:50 PM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Thanks Dana for parts and help. You have my business!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85cmroz28
Oct 4, 2015 09:44 PM
wisemanz28
Sep 20, 2015 01:26 PM
eduardosac
Sep 16, 2015 02:18 PM
Stroopwafel
Sep 11, 2015 06:38 AM
