Changing 2.73 to 3.42 gears, '88 Iroc
Old Jan 29, 2011 | 01:30 PM
Rick11949's Avatar
How difficult is it to change from the stock 2.73 rear to 3.42 gears using a Summit kit? I have fairly good skills and years of experience but have never changed a rear. Has anyone here done it?
Old Jan 29, 2011 | 01:44 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Changing 2.73 to 3.42 gears, '88 Iroc
Welcome to TGO. A search on site is generally a good idea, as there aren't many questions that haven't been asked and answered. The following link will show you what's involved:
https://www.thirdgen.org/forums/tran...axle-gear.html
JamesC
Old Jan 29, 2011 | 03:20 PM
big gear head's Avatar
The Summit kit is not very good. It's just a reboxed Ratech kit. There are much better kits availble. The better the kit the easier the installation. You will need the thick 3.42 gears to fit your 2 series differential. You will need to know how to set the pinion detph, bearing preload and backlash. You will also need to know how to read the contact pattern so that you will know what adjsutments need to be made to the pinion depth and backlash.
Old Jan 29, 2011 | 06:47 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
if your engine is mostly stock some year v6 camaros come stock with 3.42 rears.they bolt right in and are the same as the v8 rears.i have one in my 89 rs.
jklein337
Sep 19, 2018 06:23 PM
draco
Oct 4, 2015 09:25 PM
mustangman65_79
Aug 11, 2015 03:17 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
