Short Throws!!!!
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
Short Throws!!!!
what short throw shifter would be best for a manual trans. t-5 or t-56. please post pics if posible.
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Short Throws!!!!
i use a hurst billet one for the t-56 sorry no pics
The same shifters won't fit both transmissions so that's not a very meaningful question.
For the T-56, AFAIK the only ones there are, are Hurst, B&M, and Pro5.0. I haven't really heard any complaints about any of them, whoever has whichever one seems to like it. I have the Hurst on mine. It makes the stock one feel like a rubber band connected to a bowl of oatmeal, by comparison.
I also had a Hurst on my T-5. It was actually the VERY FIRST mod I did to the car, when it was still fairly new, after I got upset with my knuckles hitting the dash shifting into 3rd, even before I took out the stupid z-bar crap and threw it in the trash, and put in a hydraulic setup; I guess it was probably in about 1985. It stayed with the car through literally DOZENS of T-5s, until I put a T-56 in it.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
ive got a hurst on my t-5 and i love it...it could use to have a shorter stick on it though as its the stock height which most of you know is almost to the roof high lol
works great though
works great though
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I have the hurst with there billit handle, I to didn't like the height so I tapped it down lower on the stick and cut 2" off the top. Love it now, very short throws, plenty of clearance for hands even with a bigger head unit
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I've had a Pro 5.0 in my RS since 2006. Other than absolutely hating the gear rattle and noise through the ****, its a fantastic shifter. Its a touch notchy...I've only put 12k on it in those 5 years. I'm hoping it breaks in, eventually.
Would I buy it again? Absolutely.
skinny z
Oct 5, 2015 06:23 PM
