new rear gears
Old Feb 11, 2011 | 10:35 PM
monsterjam5000's Avatar
new rear gears
im going to rebuild my rear end with a higher gear and new posi, i want a 373 or 411 leaning more towards the 373. if i do this will i have to reprogram the computer so my shift points stay the same.
i dont want any problems and dont know how the computer will react to the rear gear change.
also will the gears and posi from my 1979 camaro 7.5 ten bolt fit my 1991 forumla firebird?
Old Feb 12, 2011 | 01:12 PM
big gear head's Avatar
Re: new rear gears
The '79 Camaro doesn't have a 7.5 rear end. All Camaros from '71 to '81 had the 8.5 rear end, so no, the gears will not fit.
Old Feb 12, 2011 | 02:54 PM
Re: new rear gears
Ine must have been changes before I bought the car, my 79 had a 7.5 ten bolt. With a 373 posi. I put in a 411 posi, And did no know if the 1991 formulas had a 7.5 ten bolt.
Old Feb 12, 2011 | 03:33 PM
Re: new rear gears
Someone could have installed a '76 or later 6 cylinder Nova 7.5 in it, but that would require moving the spring perches. No 2nd gen Camaros had the 7.5 rear end. Your '91 will have the 7.6 (same as the 7.5 but a little stronger) 10 bolt with 28 spline axles.
Old Feb 12, 2011 | 10:20 PM
Re: new rear gears
So any 7.5 gear and posi will fit? What does it usally cost to have new gears and posi installed in a rear end? Don't want to get ripped off.
Old Feb 12, 2011 | 11:44 PM
Re: new rear gears
Also does the computer have to be reprogrammed for the electronic transmission. And fuel injection?
Old Feb 13, 2011 | 05:49 PM
Re: new rear gears
Yes, 7.5 or 7.6 gears and differential can be installed in the '91 rear end, as long as the diff is 28 spline and the correct series for the gears that you want to use. Look through this. It will answer a lot of questions. https://www.thirdgen.org/forums/tran...-10-bolts.html
Old Feb 13, 2011 | 06:01 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: new rear gears
Are u running tpi? If so, it will not like 373 or 411. You will be quicker with 342 or 323.
Old Feb 14, 2011 | 08:53 AM
Re: new rear gears
why will it not like 373 or 411 thats the info im looking for i dont want to install something and make my car slower. i have the 373 and posi so i wanted to use them because its cheaper to use what you have instead of buying new.
Old Feb 14, 2011 | 10:45 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: new rear gears
Why? because you have a certain usable powerband. The lower gears like 373 will get you to the max of your powerband tooo quickly. Basically, throwing you out of where your max torque and hp is.
Old Feb 14, 2011 | 10:48 AM
ninetyone's Avatar
Axle/Gears: 3:42
Re: new rear gears
the problem is mainly with the tpi intake, but you dont really want to change that either until you get better heads and cam IMO.
Old Feb 14, 2011 | 04:29 PM
Re: new rear gears
well with any gear change do i have to reprogramme the computer
Old Feb 14, 2011 | 09:59 PM
Re: new rear gears
i found a 323 rear end from a 1994 camaro will that fit my 1991?
Old Feb 14, 2011 | 10:27 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Re: new rear gears
Yes it will, search, there is a ton of info about the 4th gen rears.
Old Feb 14, 2011 | 10:40 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: new rear gears
yes, it will fit,but it will stick out in each side a few inches. If u don't care about posi,any 3rd gen v6 firebird rear will bolt right in.They were all 323 and 342. Check the thirdgen link on installing 4 th gen rears,and sell the 373 you have.
Old Feb 14, 2011 | 10:43 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: new rear gears
what kind of car do u have? what have you done to it already?
Old Feb 14, 2011 | 10:46 PM
Re: new rear gears
if i go with a v6 rear end i would like to use a spool how well to they hold up?
also will i need the computer reprogrammed
Old Feb 14, 2011 | 10:50 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: new rear gears
not too sure about the spool.Are you driving this on the track? you do not need to reprogram the computer. I think that is mainly for a cam swap.
Old Feb 15, 2011 | 07:46 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: new rear gears
Spool is a no no on the street.
Old Feb 15, 2011 | 10:44 AM
Re: new rear gears
A spool is dangerous on the street. It stresses the parts (axles, studs, wheels...) too much and stuff can break. You need a limited slip differential (posi) on the street so that it will give when you turn corners and not stress the parts.
Old Feb 15, 2011 | 07:03 PM
cel19's Avatar
Car: 1987 Camaro S.C
Engine: 355 ci
Re: new rear gears
Hey, got a question. Goin to rebuild the rear end in my 87 camaro for a street/ strip. Going with an eaton limited slip 28 spline with moser 28 spline axles and 3.73 ratio. Transmission will be a 700R4 built to withstand 800 horses. Personally I think it's a sweet setup. Some input of opinions would be awesome though, like if its a good combo or what not.
Old Feb 15, 2011 | 07:10 PM
Re: new rear gears
If you are planning on building the original 7.5 rear end that is in your car you are going to blow it to pieces with 800 HP. You need a stronger rear end!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
