W/C T5 fifth gear modification??
Old Feb 24, 2011 | 06:09 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
I'm having a ton of trouble locating the correct 5th gear for my 91 T5. First eBay, then the largest transmission shop in the city, gave me the wrong gear. Both the internal spline count and the tooth count are correct, it is just the overall height of the gear that is different.
The gear I keep getting is quite a bit taller, it has an extended "collar". I think it may be the non world class gear. The diameter is the same, it fits fine on the shaft, but of course you cannot fit the retaining snap ring on.
The shop I got the gear from (pretty reputable place) said I should just have a machine shop cut off the collar and that would be no problem. This seems like a terrible idea to me, but my local machine shop said it could be done, probably without too much issue.
For the T-5 experts out there, what do you think? Hopefully I'll get some pictures up right away.
Thanks!
Old Feb 24, 2011 | 06:21 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: W/C T5 fifth gear modification??
i am going to subscribe , good question . good luck .
Old Feb 24, 2011 | 11:50 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
Here is a picture comparing the two so people know what I'm working with.
Attached Thumbnails W/C T5 fifth gear modification??-gears.jpg
Old Feb 24, 2011 | 11:56 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
what is the tag # (1352-xxx) of your trans?
Old Feb 24, 2011 | 11:59 PM
jmd's Avatar
jmd
The new one is wider which is good and yeah you could machine it down so it works but I wonder if wider 5th gear was a rolling change later on and they just started selling all gears that way. Try and get ahold of bangin' bob on here or call hanlon motorsports tomorrow.
Old Feb 25, 2011 | 12:59 AM
jmd's Avatar
jmd
Page 4 of this http://www.pomoforacing.com/tech/T5Rebuild2002.pdf makes me think it's to replace a washer ring in some boxes. Yours have the ring? My old T5 did: http://monte-list.com/html/images/ma...5/WCT5tail.jpg
Old Feb 25, 2011 | 04:15 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
That is a fantastic article. Mine does not have a washer ring, all I have is a snap ring to hold the gear in place. I can't seem to find the transmission number. I've contacted Bob so hopefully he can shed some light on the issue.
Old Feb 25, 2011 | 04:38 PM
jmd's Avatar
jmd
I found that article because someone else had linked to it here on thirdgen.
Good luck.
Old Feb 26, 2011 | 10:31 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what number do you have? 13-52-070-032 ?
the taller one is what ive always seen in NON WC
Old Feb 26, 2011 | 03:08 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
That is what I figured. The tall gear has no number on it, the correct gear has 52 043 stamped on the collar.
Old Feb 26, 2011 | 03:35 PM
Engine: ls1, LB9
dont think I have another WC 5th gear. I'm sure I have the matching gear for this ratio though
Old Feb 26, 2011 | 06:31 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
It seems to be difficult to find...I've had a wanted ad up in the classifieds for some time, maybe I'll bump it up once more since I can't find it locally.
Old Feb 26, 2011 | 08:07 PM
big gear head's Avatar
Contact Rockland Standard Gear.
Old Feb 28, 2011 | 05:21 PM
Bangin Bob's Avatar
Sorry guy's haven't been on. My sister in law passed away suddenly. Anyway we machine those all the time. cutting it down is no problem. You could also machine another snap ring goove in the shaft. Some replacement shafts come with two grooves already in them. Hope this helps everyone. If you don't want to do that what tooth count is the gear? maybe we have what you need? Bob
Old Mar 1, 2011 | 10:30 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
I'm sorry to hear that Bob. Thanks for your input, I would have never thought it would be OK to cut it down...shows what I know! I was also concerned that the non-WC gears might be manufactured to different standards when compared to the WC ones. Maybe I can finally complete that transmission rebuild (your video is helping a lot with that endeavor).
Cam
Old Mar 3, 2011 | 10:23 PM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
I'm thinking just machining a second grove might be easiest. What exactly would you use to do this?
Old Mar 3, 2011 | 11:05 PM
jmd's Avatar
jmd
A lathe.
19irocz85
May 3, 2015 12:58 PM
Marlboro Man
Mar 14, 2010 06:45 PM
DerfPower509
Mar 23, 2009 02:17 PM
88 350 tpi formula
Jul 6, 2007 06:47 AM
