Just use your engine mounts to pull those diff/pinion bearings
Old Mar 6, 2011 | 08:54 PM
newZman's Avatar
Car: 99 Tahoe, 98 Buick, 84 Camaro
Engine: 350, 2800, none at the moment
I needed a bearing splitter/puller, didn't want to buy cheap one and didn't have the money for the goods so I used my engine mounts...
Didn't expect it to work but I got both the diff bearing off so far only one was totally trashed.
Attached Thumbnails Just use your engine mounts to pull those diff/pinion bearings-bear-split-pull.jpg   Just use your engine mounts to pull those diff/pinion bearings-bear-split-pull-t.jpg   Just use your engine mounts to pull those diff/pinion bearings-bearing-pulled.jpg
Old Mar 6, 2011 | 08:57 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: Just use your engine mounts to pull those diff/pinion bearings
hahahaha awesome, hey whatever gets the job done
Old Mar 7, 2011 | 07:14 PM
newZman's Avatar
Well it didn't work so well on the pinion bearing. The one motor mounts started to take on new shapes and bent one of the 1/4 inch mild steel adapters I made for pulling from the longer shaft. I'll try a real tool for that one I guess, didn't mess up the bearing too bad though.
Vintageracer
Jan 10, 2020 05:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
